Transfer Money To China
coutuser
Hi,
I need to transfer RMB 8K to someone in China.
Is it better to to do this via Alipay or should I go to a money changer in Chinatown?
What are the charges for using Alipay?
I understand that you can only add Visa and Mastercard so I believe the fees are high?
Or should I just use bank transfer using POSB or OCBC?
Need people to advice.
Thanks.
SibehHL
Easiest way is via remittance houses in People's Park unless you have Alipay/Wechat China account. Each transfer cost I think S$18 and a slightly better FX than banks.
beanstalk6
Moderator
Moderator
Agree. You are better off going to a remittance agency at People's Park for simplicity and low costs since you have no access to Alipay or a Chinese digital wallet.
testerjp
What about transferwise and worldfirst, will those work?
jayceevee
Hi,
Thanks.
Have you found the way to do this?
beanstalk6
Moderator
Moderator
Or a remittance agency at People's Park. They do these kind of transfers all the time.
Upzzzz
doing remittance at Chinatown carry some risk. There are many stories of receiving Bank account being frozen by authority as the account used to transfer the money is being suspected of laundering. Now the remittance companies will let u sign an indemnity form.
so avoid getting people into trouble, use DBS.
SibehHL
Most folks who has account frozen are transferring amounts over RMB20K and those who transfer very frequently. Can't say it won't happen to some unlucky chap but unlikely for someone doing a one-off RMB 8K transfer.
To think about it, if freezing accounts happen very frequently and to many people then all these remittance houses would have closed shop long ago.
Upzzzz
a greater extend depends on what accounts are used to transfer monies into recipients account.
innumerabilis
darksaint
Hi,
Thanks.
can try this https://www.remitly.com/sg/en/china
kkboy1
Remittance only works for transfer to local Chinese.
I have china bank account but remittance does not work as I do not have a china national ID to receive.
The strange thing is local chinese can transfer to my china bank account.
