watzup_ken
- Nov 21, 2003
Starting a discussion to see what fans do you folks use/ prefer?
Just sharing my experience with the fans I've experienced and my preference. For me, I always prioritise airflow in the case, so I tend to play around with different fans to get a good balance between airflow and noise. I am not going into details, but just sharing my experience so that you can then go and check out for reviews of the fan and decide if it suits you. As you can tell, there is not RGB fans because I prefer a black out system.
1. SanAce 120mm - This is one of my early favourite fan that I used in my early DIY days. I believe I got these and also a pair of Delta fans from Gary, the shop at level 2 over SLS, many years back. I still have 2 of these made in Japan fans. I feel the air pressure is quite good and the fan ran quite quiet. These are non PWM fans by the way and are I think at least a decade old. Still working well fortunately.
2. Corsair ML120/140 - Had a couple of the ML120 and 1x 140mm, and to be honest, these are fans I dislike most. Airflow is great, but it sounds like a cordless vacuum at full throttle.
3. Fractal Design Venturi 120mm - I feel this is a fan that is a good balance between airflow/ pressure and noise. I used this on my HTPC cooler, ID Cooling IS 50, and it worked very well and silently.
4. Arctic P12 - These are one of the best value fans I've ever used. I think there are a lot of reviews on them, so the reviews speak for themselves. In particular, I feel that the BionIX P12 are generally overlooked. These spins faster and are also very silent even at full speed. If you are looking for cheap and good fans, I strongly recommend this.
5. XPG Vento Pro (aka Gentle Typhoon) - I've never tried a Gentle Typhoon in the past, but recently got a few of these to try out. Airflow wise, its excellent, beating even the P12 BionIX based on my subjective experience. Noise level is however, quite a fair bit higher when comparing at full speed. I got this over the Noctua NF A12 because they are cheaper.
6. Phantek T30 - Just ordered this to try out. Will update.
In terms of top 2 preference for 2021,
1. Arctic BionIX P12 - It is cheap and works really well. The downside is that the build of the fan is not as sturdy as say a Vento Pro.
2. Vento Pro - Based on reviews out there, the Gentle Typhoon here have a slight edge in terms of airflow due to higher RPM. But the noise level is higher. The reason for recommending these is because they are cheaper. These may however get replaced by the T30 that I just ordered.
