Elijahonli
- Oct 27, 2008
I looking for a 1U case that allows my ports to face front. This is so I can access all the ports easily and swap with my switch. Anyone seen one that can do this?
Step 1: Select 8 to enter into Shell
Step 2: Access the boot folder
TYPE:
cd /boot
Step 3: Access the boot loader config file to edit
TYPE:
ee loader.conf
Step 4: Append the following parameter to specify the max arc size
TYPE:
vfs.zfs.arc_max="2048M"
Step 5: Press Esc and choose a) to SAVE.
Step 6: exit Shell and select 5 to reboot.
Those who using pfblocker NG, I have a question :
1) are we able to schedule the rules to off for certain a device? e.g Monday - Friday 10am-7pm?
Sent from A universe Where pink PWNED everything
I don't use that. But I think you meant "time based rules".
Read:
https://docs.netgate.com/pfsense/en/latest/firewall/time-based-rules.html
You can find the video tutorial on scheduling of firewall rules on the first page of this thread. It should not be a problem since any rules created from pfblockerNG could be found under "floating" rules section. There is a setting under "schedule" where you can make changes and set routine schedules.
1. Don't change to the ONR. Getting permission for bridging is a hit-and-miss, but it's also the exception rather than the norm. If you have the ONT, fight to stick to the ONT. The 2Gbs plan generally not benefit most people in terms of bandwidth - but perhaps you have 20 or more people staying at home with you and all using the bandwidth at the same time. If it's the normal 5 or fewer pax household, a 500Mbps/1Gbps plan is more than sufficient imo.Hey! I need help planning out my network, not sure if what I have in mind makes sense.
I have an ONT with SIngtel 1Gbps plan, upgrading to Singtel 2Gbps with a pair of Singtel Mesh Extender AC2600. That upgrade will (I THINK) change the ONT to an ONR. Currently I intend to have an OPNSense box from the ONT/ONR to 2 different routers. The idea is to have 2 different networks in the house. 1 should be untouched for other household members to use. The other is for me to start playing around with OPNSense and learn about networking. Because my room is the furthest from the router, the second network will be through the 2 mesh extenders (via wireless backhaul). The first network will be just be via a generic router like an ASUS RT-AX86U.
I have a few questions, if you could shed some light.
1) Is there a difference between an ONT/ONR? Should I want one over the other?
2) Can I set up VLANs based on what I said on the OPNSense box?
3) Any gotchas I should look out for when using Singtel Mesh Extender AC2600?
Hey, Eraserpencil here. Had the mods deactivate that in favor of this.1. Don't change to the ONR. Getting permission for bridging is a hit-and-miss, but it's also the exception rather than the norm. If you have the ONT, fight to stick to the ONT. The 2Gbs plan generally not benefit most people in terms of bandwidth - but perhaps you have 20 or more people staying at home with you and all using the bandwidth at the same time. If it's the normal 5 or fewer pax household, a 500Mbps/1Gbps plan is more than sufficient imo.(Just fwiw, Netflix streaming at 4k only requires 25Mbps). In any case, with the 2Gbps plan, it's split into 1+1: 1 Gbps bridged, and the other you're forced to be unbridged. It's "combined" by Singtel's proprietary router, so effectively you either remove your OPNsense box from the network, or you run it at 1Gbps anyway.
2. VLANs are the way to go so you will only need one set of infrastructure and VLAN tag appropriately. You don't need separate wireless equipment for that - just cofigure tags and switch as needed.
A router behind a router causes Double-NAT. The ONR does Routing, whereas the ONT does not. Double-NAT is all bad, primarly because it breaks point-to-point applications of the Internet. It may not be obvious sometimes, but these are the compromises made because of the explosion of devices that require internet access.Hey, Eraserpencil here. Had the mods deactivate that in favor of this.
I just realise the Singtel devices for the 2Gbps and the 1 Gbps plans support up to wifi 5. I would probably get a 1Gbps plan then and use the free router as the common one for the house. Would you suggest getting a pair of XT8s or 2 stand alone APs (like an RT-AX86U) to do the wireless-backhauled mesh network for me to test out OPNSense.
Not really sure what the concern about bridging is...
I have not sign the recontract yet. Gonna fight for ONT.Just wondering if you can talk to Singtel and not to upgrade to 2Gbps plan, that is the worst plan for you to play with pfSense/OPNSense/etc. I can even say it is the worst plan from Singtel. You simply can not bridge the ONR for the 2Gbps plan. (BTW, it is the same for Viewquest 2Gbps plan). And the free mesh comes with it is not good.
You should stick to the original 1Gbps plan with ONT if you want to play with two networks. You just need to buy a VLAN capable switch to create two seperate networks. I am doing that myself with the cheap TP-Link TL-SG105E. You can actually create three seperate networks but usually you do not need it. I use one network with RT-AX82U for family use and Singtel TV, then I use the other network to play with pfSense/OpenWRT/etc.
If you have already signed up for Singtel 2Gbps, try to negotiate with Singtel to change to 1+1 Gbps plan where you do get two seperate networks, one port bridged (you can play with OPNsense or pfSense here, no VLAN required) and the other three port unbriged (you can use the free RT-AX86U which comes free with the 1+1 plan). In this case, you do not need to setup VLAN.
If i understand correctly, I need 3 APs, 1 switch, 1 OPNSense box. Yea? ONT -> switch. 1 connection from the switch go to 1 AP(lets say whatever Singtel gives for free) for general home use. Another connection go to another lets say an RT-AX82U, which will act as a wireless extender to another RT-AX82U, then my devices connect to that.
i just need to setup the VLANs on the switch right?
