Thanks. How about turning off the LED and scheduling reboot, need the app for that?
The reason I'm asking is because the Xiaomi AX3600 required the app for those extra functions.
Just wondering what is the concern of installing the mobile app? For the China version of AX3 Pro, it is rather troublesome and you may not really be able to use it (need to use a Huawei China account, some say have workaround). But for Global version, it should not be so difficult to install the Huawei AILife app to control the global version of Huawei AX3 Quad Core version.
I have the China version of AX3 Pro (Quad Core version) but the global version should be similar. I do not use the mobile app myself since I actually run my Huawei AX3 Pro in AP mode, not in router mode.
Schedule wifi off time -- yes for the web UI
Schedule reboot of the router -- only in the mobile app
Status LED ON/OFF -- only in the mobile app
SpeedTest -- only in the mobile app
Mobile app specific firewal and parent control function -- only in mobile app
It is the same for Huawei and Xiaomi that the Web UI has less function and the mobile app has more functions.
But for Xiaomi AX3600, you can enable SSH to gain more functions not available in the web UI and the mobile app. It is not possible to gain SSH access to Huawei AX3 Pro router.
But then at S$58, you can not complain about the Huawei.
