Just installed 2x with tornado flush for my 2x toilets. It has 2x slow-closure covers. The top white cover has another transparent plastic cover over it (last photo)
Not every shop carries every brand. And because my toilet water pipes are high a number of tornado-flush bowls were excluded.I almost bought the same one, but went for Magnum 918s at the end, due to the cost and similarities
Tornado Flush - A lot of hype
After using my new toilet bowl for a few days I realized the tornado flush is a hype. Heard a lot about how strong and how clean it can flush but all just plain BS ah.
It still cannot flush some sticky sai just above the puddle of water and those inside the puddle of water sticking to the bowl. I still need to use a jet hose to spray to dislodge those sticky sai on the side of the bowl. As for those bits inside the puddle of water at the bottom of the bowl I used a toilet brush to scrub them off
So much so for tornado flush ah
Never mind what brand and type of tornado flushYah i also thought tornado power, but the salesperson was saying the advantage of AS tornado flush is more for the quieter water gushing sound. In the end i just went with their double vortex one. No chance to use yet.
But i thought i saw some rating somewhere AS tornado itself is not that good as Toto all that... but anyway yah i like the glossy plastic on top of lid lol
if u got a lot of sticky sai everyday, consider eating more fruits and drink more water?Tornado (Vortex) Flush - A lot of hype
fill up pail of water, then u manual flush la. because of the force that u manual flush, the water level should drop, thus exposing the sticky sai. then u use bidet spray spray la. else for super sticky sai , use tissue paper manually wipe. i don't like to use toilet brush brush it.. yucks. later the sticky sai stick to your brush lei ..Never mind what brand and type of tornado flush
It cannot flush those sticky sai at the bottom of the bowl inside the puddle of water. The reason is that the puddle of water acts like a shock absorber (buffer) to absorb and dissipate all those tornado forces/jet hose water force acting on it. If the forces cannot hit the sai then the sai cannot be cleaned. Just have to manually scrub with a toilet brush lor
Thank you for your honest review. Helpful for us still deciding which brands/models to purchase.Tornado (Vortex) Flush - A lot of hype
it's a problem that could be specific to the exact w.c. model that you bought. I have 3 different tornado flush w.c., none exhibit this issue you have described.Tornado (Vortex) Flush - A lot of hype
It still cannot flush some sticky sai just above the puddle of water and those inside the puddle of water sticking to the bowl. I still need to use a jet hose to spray to dislodge those sticky sai on the side of the bowl. As for those bits inside the puddle of water at the bottom of the bowl if the jet spray cannot remove them then I use a toilet brush to scrub them off
What brand you buy? Can go to your house and pang sai to test them?it's a problem that could be specific to the exact w.c. model that you bought. I have 3 different tornado flush w.c., none exhibit this issue you have described.
Toto, you can physically test them out at the W Atelier showroom in Henderson Road, they have furnished their public restrooms with various Toto w.c.What brand you buy? Can go to your house and pang sai to test them?
Boss can share with me where u get this at $699 each?Just installed 2x with dual flush double vortex (tornado) flush for my 2x toilets. It has 2x slow-closure covers. The top white cover has another transparent plastic cover over it (last photo). It costs $699 each
https://www.americanstandard.com.sg/bathrooms/toilets/signature-close-coupled-back-to-wall-toilet
Wait lah. I'm at work now. I need to go back this evening to get the name of the shop from the receipt.Boss can share with me where u get this at $699 each?
Thanks!
$699 sounds like a lot for an ordinary looking toilet bowl…Boss can share with me where u get this at $699 each?
Thanks!
