What to look out for when buying 2nd hand graphic card in Carousell
rathalos
I bought one second hand rx570 from carousell.. so far ok, been using it for like 2+ years...
Vegitto
Unless you have a tight budget of less than 800, if not I suggest you wait half a year more for rtx 40 series
86technie
1) Price
Old graphic card like GTX7XX/GTX900 are not worth $200 - $300.
I saw one selling GTX780 for $300 is too high.
2) Condition of the card like oxidation, rust, scratches especially on the golden pin.
Will have lower value.
3) Bring home have to dust and test.
If you want reliable graphic card get brand new one like GTX1650 which is failing back to it's original MSRP below $300.
Other models hopefully will drop.
2nd hand graphic card is 50/50, you can buy a graphic card either have issue or don't know when it will die.
Mining cards avoid those not only used prolong but overclock also.
I have brought used graphic card but I won't spend more than $100.
monocoque
eh, udk HWZ rules?
1. make sure dont buy from sellers that NPNT
2. find seller with pic of chiobu
then CSI to see she's real, where she stay, what's her IG
3. then proceed to lowball her an offer
