brianlee_sg
- Aug 6, 2004
Didn’t buy a lot but at least Get to lock in the interest rate higher than OA for the next 10 years.
marginally higher...Didn’t buy a lot but at least Get to lock in the interest rate higher than OA for the next 10 years.
I bid competitive higher than cutoff yield so will be refunded.You will be paid coupon rate. I believe the rest will be refunded as lzydata has explained to us.
so for a competitive bid of 2.68% means unsuccessful and full refund? thanks2.625%
if you get it the difference will be refunded to you.
Successful.so for a competitive bid of 2.68% means unsuccessful and full refund? thanks
But trying to understand how new issue SGS works.
So interest half yearly based on coupon rate 2.625% for next 10 years
If get $10,000 how much will be refunded ? $74 ?
so successful allotment is pegged to the cut off yield of 2.71% but the coupon (interest) is 2.625%? again please help me dumb it down a notch so i can understand better. in short what is my return vs OA 2.5% as i have used OA for this auction ? many thanks reddevil0728Successful.
cut off yield that matters.
You will receive coupons at 2.625, but the price you pay for the bond is 99.26 after getting the refund of 0.74. This is what gives the yield of 2.71% which can be calculated in Excel or bond calculators.so successful allotment is pegged to the cut off yield of 2.71% but the coupon (interest) is 2.625%? again please help me dumb it down a notch so i can understand better. in short what is my return vs OA 2.5% as i have used OA for this auction ? many thanks reddevil0728
Technically 2.71% if you hold it for 10 years.so successful allotment is pegged to the cut off yield of 2.71% but the coupon (interest) is 2.625%? again please help me dumb it down a notch so i can understand better. in short what is my return vs OA 2.5% as i have used OA for this auction ? many thanks reddevil0728
I thought to buy with OA but decided not too seeing US Tresures drops a lot recently.Didn’t buy a lot but at least Get to lock in the interest rate higher than OA for the next 10 years.
Need to see 10y yield.I thought to buy with OA but decided not too seeing US Tresures drops a lot recently.
Right so marignally higher may not be good enough to overtake OA.....Btw I see some people compare this 10 year SGS to CPF OA.
However, there is an important difference - CPF interest is compounded. SGS bond interest is not.
$100 at 2.5% pa compounded after 10 years is $128.
$100 in this SGS bond earning $2.625 coupon annually gives in total $126.25.
That’s why it needs to be higher enough to make sense to use CPF OA.Btw I see some people compare this 10 year SGS to CPF OA.
so for OA $100k the math is .....Btw I see some people compare this 10 year SGS to CPF OA.
But cut off yield is 2.71% for this. So will be slightly higherso for OA $100k the math is .....
$100000 at 2.5% pa compounded after 10 years is $128000
$100000 in this SGS bond earning $2.625 coupon annually gives in total $126250
i see why you say will be slightly higher because have to take into account the refund of $740?But cut off yield is 2.71% for this. So will be slightly higher
Ya.i see why you say will be slightly higher because have to take into account the refund of $740?
and because i intend to reinvest the coupons back to CPF via VC3A every 6 months it should narrow the difference between remaining and compounding in OA vs buying this 10 year bond ? thanks again.Ya.
see my post above. About the money you will get.
