Google Pixel 7 series
What upgrade would you most like to see on the Pixel 7 series?
  • Total voters
    140
Vulpix
Moderator
Moderator
Si bei good… it allows u to charge battery more than once a day, and when weather is cold, u have a hand warmer in your pocket as and when u need it. Isnt that great?
Actually that can be said for any snapdragon 8g1 chipset. :s13:
Vulpix
Moderator
Moderator
Sd8+g1 is fine cos is by tsmc. In fact it is way better. Rog phone 6 is good in terms of this
If only I had some trust in ASUS. Otherwise might have gotten their ROG 6. BTW the embargo date for reviews is October 12 for those curious. Burgerland time.
wongminmin
GUYS, BUY ON SHOPEE IN 2 DAYS TIME
$1449 - $70 (platform voucher) - $100 (SHOP voucher) - $250 (for next purchase) = $1029
but sianz...only black color. :(
Vulpix
Moderator
Moderator
Why cannot use on the 128gb version? The 70 bucks platform voucher is min how much? I have a feeling the shopee store will prevent you from using the $100 coupon on the 7 but we shall see.
Loser
Sure can use the shopee mall voucher on this and also the shop voucher will apply for pixel 7 pro?
That's the best deal if can.
Vulpix
Moderator
Moderator
min $1000
Hmm ok. I wonder if I should take the leap. But I am fairly confident the store in Shopee will prevent you from using the $100 coupon on the 7 series as shops are allowed to select which products the coupon can be used on.
