hotspur_77
- Jan 23, 2005
It will be launched this month, $1399Anyone knows when the 27 lg oled monitor will come to sg?
totally not worth it at that price point seeing how dim it could be.It will be launched this month, $1399
i thought the new 27 inch lg oled panels are using mla?totally not worth it at that price point seeing how dim it could be.
Alienware way better in the brightness of its QD oled.
Wa pain, any pre order bonus? Where did you get the info btwIt will be launched this month, $1399
just not worth the price. QD Oled definitely better where you can go Wow when u see the picture quality in relation to its brightness.
yea matte screen spoiler for oledthe comments there mentioned that disabling smart energy mode solved it.
but.. matte screen is no go...
So far, these energy saving mode is not ideal for OLED. It affects brightness level greatly. My OLED TV can get so dim that I thought its broken.the comments there mentioned that disabling smart energy mode solved it.
The QD oled from aw not matte?yea matte screen spoiler for oled
no ah glossy. its marketed as semi glossy. but to me its glossy. similar to my LG CX tv.The QD oled from aw not matte?
I see, I am intending to use dual monitor setup. Currently 2x 27 Lg GL850. Thinking of getting the 27 oled as my main gaming monitor, not sure if can fit the aw3423 on my desk with the second 27 monitor lolno ah glossy. its marketed as semi glossy. but to me its glossy. similar to my LG CX tv.
Most of the time i run in SDR mode too. And i not using max brightness as its too bright for me.
Currently listed on challenger website as 'sold out'.Wa pain, any pre order bonus? Where did you get the info btw
Wa shag, this is the monitor I wanna get lol. But very expensive for early adopterCurrently listed on challenger website as 'sold out'.
https://www.challenger.sg/game-on/p...ng-monitor0--8806091419309?h=MCwxLDAqMTM5OQ==
Guys, those of you that are using 34” UW monitors, which monitor arm would you recommend?
Did some research online and have come across the following.
https://desky.sg/products/heavy-duty-single-monitor-arm
https://prismplus.sg/collections/monitor-arms/products/arc-titan
https://www.ergotron.com/en-us/prod...#?color=black&attachment option=2-Piece Clamp
https://vivo-us.com/products/stand-v101g1
UW monitors are generally not heavy, unless you are using something like a Samsung Odyssey G9. Most cheap monitor arm will work. It makes no difference. They may be cheap, but no perceivable difference from one that cost a lot more. One good brand I have in mind is Northen Bayou.Guys, those of you that are using 34” UW monitors, which monitor arm would you recommend?
