Eh definitely not?it is advisable to bid Non-competitive.. ? About to submit..
You should bid non-competitive if you are willing to accept any cutoff price for the bond. You will almost certainly get the full allotment of the amount you put in unless there is a huge increase in NC bids, in which case you will get a prorated allotment.it is advisable to bid Non-competitive.. ? About to submit..
@lzydataUsing XIRR to calculate the YTM for this 2-year bond (N520100A), I arrived at the yield of 3.62% based on the closing price 93.57 and accrued interest $1.60 (for a $1k par value).
Can anyone explain why the YTM for this bond is lower at 3.59% according to MAS website?
Thanks.
don't know what's MAS calculatorSorry, no ideaSince it is MAS's calculator, ask them?
The SSB SBSEP23 application is also closing today. If you get the SSB and hold it for up to two years, you will earn 3.01% pa. Same issuer - the Singapore government - with more flexibility than the SGS bond in that you can redeem anytime and be guaranteed your principal and accrued interest.
Hence the logic of putting a competitive bid of 3.02% pa, because if the SGS bond yields 3.01% pa or less, that's not worth it for you - you might as well get the SSB. And there are also other alternatives.
This is the reasoning behind competitive bidding.
If you really don't understand all this and just do not want to commit to any number, then bid non-competitive. Almost all the time you will be fine, just that you have a (pretty small) chance of not being allotted in full - if there are too many people bidding non-competitive.
Never mind.
Eh definitely not?
do you you know how nc works?
thanks ocean!
maybe my inputs or logic is not correct. Never mind, it's ok. Thanks.thanks ocean!
I always do my own calculations for YTMmaybe my inputs or logic is not correct. Never mind, it's ok. Thanks.
buffer for swing in the cut off yieldanyone know why bank needs to charge 15% more as deposit for the auction for reopened bond ?
Sent from EDMWER Pro app!
because the coupon yield is fixed based on the face value.anyone know why bank needs to charge 15% more as deposit for the auction for reopened bond ?
Results is out.
Trying to understand how SGS re-open bonds work. Look at cutoff yield or closing yield ?
Anyone can show illustration based on numbers ?
same approach as t-bill.Results is out.
Definitely don't look at the closing yield at the top, look under Auction Results.
And when I mouseover the "i"s i see this:
Cut-off Yield - calculated based on the clean price
Cut-off Price - includes accrued interest (i.e. dirty price)
3.56% p.a. and 93.869 - so the cut-off yield is clean but the cut-off price is dirty
The cut-off price is what you would actually pay for the bond (i.e. get a refund of 6.131 per 100). The cut-off yield is like for you to understand what your money is yielding.
In the SGS bond calculator, I choose N520100A, settlement date 4 Sep 2023 and price 93.69, because this input is for clean price. It computes accrued interest as 1.70 and dirty price as hence $93.69 + $0.17 = $93.86. This roughly matches the Auction Result's 93.869 which is the dirty price.
https://www.mas.gov.sg/bonds-and-bi...ore-government-securities/sgs-bond-calculator
