[GPGT] Those HDB built in 1990s really damn big sia ~ floor space 2000 sqft !
neutralph
Really damn big sia
got 2 entrances some more
we'll never see this type of units again
fwah, 3 toilets.
nyvrem
i tell u
got some ppl in edmw can argue with u for days and nights and even for months on why the new pathetic bto is better than 1980s spacious flats
they haypi can riao
we know how good life was back then
:o:o:o
virtualape
Yes, I remember wanna drill walls ***** difficult. Or maybe I'm not so skilled. New flats very easy.
Need a good drill for concrete or brick walls.
New flats iirc some might be using thicker plaster board with wooden frame backing. Lighter items can hold.
Tabula Rasa
I remember the drill head got damaged. But those contractor worker one seem much better. Not sure if cos of skill issue, or cos their equipment better.
virtualape
Get a better quality drill bit. Or were you drilling reinforced pillars??
Tabula Rasa
i tell u
got some ppl in edmw can argue with u for days and nights and even for months on why the new pathetic bto of the 2010s and 2020s are better than 1970s 1980s 1990s spacious flats
The newer batch of BTOs is really not so good, have heard a lot of complaints about build quality. Possibly cos affected by Covid. Hopefully things are better after the complaints have been taken into consideration. In the early 2010s, it was still not too bad.
