Dead Pirate Roberts
- Jan 3, 2023
My 10g is based overseas not in sgAre you on SI or ST?
I am waiting for ISPs to introduce new place so that I can do speedtest like this and post on youtube![]()
Direct lan connection from my iMac
yup its using the dual-WAN load balancing in Qhora-301WOk, so the bonding is at the QNAP ?
hello guru,yup its using the dual-WAN load balancing in Qhora-301W
hello guru,
Is there anymore settings needed for dual-WAN load balancing?
I have 2x 1Gbps Myrepublic gamer fibre plan. I got an ASUS ROG AX11000 router. I enabled Dual-WAN load balancing with 1:1 ratio. However whenever I do a speed test, i'm only averaging around 600Mbps - 800Mbps, which feels like they're just using 1 WAN link. Am I doing something wrong?
I am using qhora 301 as my router so settings is diff from yours. For me it’s quite auto and no other configuration neededhello guru,
for your cases, what’s your client (mobile, pc?) and connection (wifi5/6, lan - 1g, 2.5g/10g?)
for most mobile clients like iPhones, 600-800mbps is a norm, and sufficient for mobile apps.
to get more than 1gbps speed, your client will likely to be a pc with more than 1gbps network connectivity.
It is said that you need static IP add-on to get Asus Dual WAN Load Balancing to work properly. Do you have static IP add-on?
Are you carrying out SpeedTest using wired connection from the 2.5G LAN port using a 2.5G capable device? If you use device with gigabit Ethernet then of course the speed will be less than 1Gbps. If using wireless then it will depend on the wireless client and you may not get above 1Gbps.
static ip exposes your network directly to wan. do you do anything to firewall it ?
just for layman knowledgeThat is not correct. You will need a Firewall for your home network and it has nothing to do with using Static IP or Dynamic IP. More sophisticated Firewall like pfSense has different Firewall rules which can apply to WAN (no matter it is dynamic IP or static IP or even CGNAT) and LAN (including VLANs).
It is just Static IP may get more attacking surfaces if you have opened some network ports. So yes the users with Static IP may need to be more careful.
I am considering upgrading my current 1 Gbps to 2 x1 Gbps due to overuse of bandwidth. I have no concern on limiting to 1 Gbps on speed but as long bandwidth is enough will be ok. Would like advice on what aggregation router to get for this setup. Thanks.
The goal is to increase bandwidth coz too many users but prefer to stick to single network.What is the plan you want to sign up? What is the goal?
Your statement "no concerns on limiting to 1Gbps on speed" and "aggregation router" do not match. When people using a router with Dual WAN Load Balancing, they want to get above 1Gbps speed (about 1.8Gbps) with a single connection (say from the 2.5G LAN port).
Do you run 2 networks or aggregate the different ISPs?I would use 2 different ISP for 2x 1Gbps more for redundancy. There was once starhub is down, my M1 still can keep be use. Another time, I also encounter my M1 fibre down and need to wait for 2 days before they repair the broken fibre outside.
I aggregate the different ISP together. I wasnt able to get full speed with my previous gateway as is not fast enough and the max i got was only around 1.4Gbps. After changing to another gateway, getting around 2Gbps is for speedtest is not an issue.The goal is to increase bandwidth coz too many users but prefer to stick to single network.
Now MR 10Gbps is so cheap, why never consider taking 10Gbps? During renovation can ask contractor to do the cabling.How did you put good use to 2 X 1Gbps ?
think there are many ISP having 2 X 1Gbps plan.
If you have a router that support dual wan then you can connect 2 X 1Gbps but you will not get 2 Gbps but 1Gbps.
From my understanding the router will use the 1Gbps that are more "Free" when upload and down (you get what i mean)
However i think the best use is to have 2 connection , one to new router while the other for torrent and etc.
I wonder how other people have make any good use of the other 1Gbps for such plan.
Actually getting 1.4 Gbps is normal for wifi at least it is beyond the traditional 1Gbps speed.I aggregate the different ISP together. I wasnt able to get full speed with my previous gateway as is not fast enough and the max i got was only around 1.4Gbps. After changing to another gateway, getting around 2Gbps is for speedtest is not an issue.
its most probably the design of your internal network rather than bandwidth limitation.The goal is to increase bandwidth coz too many users but prefer to stick to single network.
