LG gives the most savings in $Better not. Just use mitshibishi electric if u planning long term.
I found it at google …u complied these data yourself?
prism+ zero is good for rental units![]()
Currently we are using Mitsubishi which has served us very well for more than 10 years (inverter).u complied these data yourself?
Dont be penny wise pound foolish like many here.I found it at google …
I m thinking to change my sg house cos with the heat increasing annually, the current air con isn’t sufficient to cool the room..,
Daikin and Mitsubishi are good. I started with misubishi then Daikin.Currently we are using Mitsubishi which has served us very well for more than 10 years (inverter).
With sg high cost in electricity, thinking a double inverter will save us more $…
sg all split system… my is single unit
I prefer single unit compressor
If within first yr need to topup gas means they nvr do a proper job n there's a leakage. Of course they top up for u for free. Beats finding the leakDaikin and Mitsubishi are good. I started with misubishi then Daikin.
You can change gas to make it colder. If within first year is usually free.
You are correct. And I got it from gain city. What to do many of the Malaysians no exp.If within first yr need to topup gas means they nvr do a proper job n there's a leakage. Of course they top up for u for free. Beats finding the leak
Another dark horse is the one at renaissance hotel. That one is still ok for me. But still a lot of sweet pastry.I have personally tried a few buffet at JB, these are the ones to avoid for sure:
1) the one at KSL, mainly fried stuff/Malay Kueh/and sweet confectionary, dark atmosphere , ok price at 60RM
2) the one at Hyatt place paradigm mall, expensive at 168rm, the variety is mainly spicy dish like Korea food, and a lot of sweet confectionary as well. And 30% is Malay food.
3) the one near komtar jbcc and near hidilao, the hotel is amari. A lot of dishes, but mainly just recycle the name, spicy prawn, fried prawn, sambal prawn, prawn sushi, you name it. For the price of 128rm, it is not worth. Very dark atmosphere as well and not many people.
Sg labour so exp, call technician down 1 time alrdy eat up all your savings.
Even if you wanna be a cheapskate, srsly, just avoid lg and samsung. Go cheapskate among the other brands.
ME and daikin the least problems.
https://forums.hardwarezone.com.sg/threads/malaysia-prepaid-card.1984062/page-185Review of onexox:
1) I got to set up esim and it's not hard, just need to call CS to transfer to esim
2) it's based on season pass
3) every month minimum must draw down 500mb, but there is workaround to pause the subscription
4) can top up till the subscription duration end, from season pass
5) 10gb for 50gb is expensive, but there is promotion frequently like 40gb for 50rm and it is very frequent.
6) now it has 5g and it's quite fast. Not like hotlink where 5g network is unstable.
It is Rm4.50 per kg which is S$1.30 per kg.Wah .. papaya in sg $3 per kg..JB not cheap..
I need a jb mobile no on my spare phone for ease of communications in jb.
Digi?Review of onexox:
