Noted on the unauthorized service personnel.
But noob here. Let's say I subscribed to the company doing the installation for me. Isn't paying for the extended warranty cheaper than buying a new system?
all ac company is heng or suay, depend 100% on the installer. GC got inhouse and subcontract installer
anyway try to go social media . search for GC and focus on ac workmanship/extended warranty, how they flip the issues to make it until not cover by workmanship warranty etc... or even flip until extended warranty not cover.
https://www.facebook.com/groups/complaintsingapore/
https://www.facebook.com/groups/SGHomeDIY/
https://www.facebook.com/groups/1644165932534557
sg reno, sg chat group from tele
for me as long as no warranty and more then $500 of total cost to fix the AC then is more worth it to change a new one
why?
cause mine system 1 and i current have 1set of system 1 at 1.4k, another system 1 will be installed in 2025 (thinking newway or amyth), my aim is 2 set of system 1.
why different date and not together the same company. my gut feeling was not to trust ac company, and to spread out the damage, if both together install, and the installer lousy, both set also gg.
back to the question extended warranty.
let say ac not cold, they say is no gas, or low gas and due to copper pipe ( let say leak is not due to the valve, fcu or compressing unit), pcb board spoil, condensation (let say due to bad installation ), compressor spoil, total cost to replace more then $500. etc.....
so it more practical for me to replace the aircon as new one with 12k btu is 1.4k (and if kena the problem as mention). if repair cost 500? 600? or 800? is not worth it to repair as usually they give only a few day or at most 1 month warranty. new one is 1 yr
it also depend on your setup like system 1, 2 , 3 or 4. but for sys 1 it a pro to have dual condenser
say extended warranty $200 + repair cost $500 = $700 and new AC is 1.4k. i just replace whole set but for system 3 or 4 cause it 3 to 4k, so it cheaper to get extend warranty or repair even if the cost 1k , as always check the repair cost vs new AC. or maybe you can try to apply HDB to install 3 condenser then get 3 system 1.
