[Help~! Help~!] LTA seeks ideas to remove burnt electric buses from multi-storey bus depots
AndroidComa
LTA should focus on how to ensure passengers evacuate faster than lighting ev fire
focus on human safety first
as usual our govt agencies losing focus and original intent
see NTUC, see simplygo, see ERP2.0
now u see even bus company is going kisiao on cost savings and putting consumer's safety not at the 1st place
Acetron
install a giant fire blanket in the bus depot and once fire starts, it will trigger and lowerr the blanket onto affect bus
anchoraz
Charge at bus stops in ulu areas overnight. The most burn bus stops only.
Industrial, east coast park service road. So many bus stops. After 11pm no use.
Can do at least 2 charging point each. Then 5am take motorbike go there fetch bus drive again.
Eost002
Water plus lithium wont jibaboom meh? Dont tell moi lta no chemistry grad ppl :crazy:
bh2148
Oh mai, now need to unburden this burden in such a short passage of time! First they need to relocate the battery pack to the back of the bus, like an extension at the back of the bus, if caught fire straight away disengaged the back extension to prevent it burning the bus body. Like a trailer cart carrying only the battery pack behind. When traveling on road you can be very sure that no other vehicles will want to follow close behind you.
HushiePuppies
What da ****? Ownself create problem??? They haven't even trial run e-buses for long enough, already order 300+???? Seriously LTA is one of the most questionable agencies leh.
you should see who is their leadership team, those career one not political appointee.
PCguy
EJB
Easy solution, perpetually soak the buses in water until need to start shift.
When 1st batch of passengers board, issue them cloth to wipe dry their seats and standing areas. Charge them $10 on top of their fares for the cloth.
Then gao dim liao.
