zz123456789
- Aug 11, 2024
any way to pre-order x870 motherboard? i already bought the amd 9600x cpu.
Depending on the chipset you are looking at, it might be better and cheaper to get the x670 motherboardsany way to pre-order x870 motherboard? i already bought the amd 9600x cpu.
are the x870 boards going to have any kind of improvements in gaming? Or are they all gonna be the same thing but differentDepending on the chipset you are looking at, it might be better and cheaper to get the x670 motherboards
https://www.pugetsystems.com/labs/a...-x670e-vs-x670-vs-b650e-vs-b650/#X870_vs_X670
X870 = X670 + USB4 + WiFi 7
If you don't need either of the last two, then X670 or even B650 will suffice.
If you are buying a motherboard now for the latest generation CPU, I guess USB 4 and WiFi 7 are both must have features.
A few months ago I chose to go with Intel Core Ultra 5 125H based laptop and not AMD Ryzen 7000/8000 series based laptop, because of USB4/TB4/TB3 (for 10G NIC) and WiFi 7.
But of course it is not too bad to add a WiFi 7 PCI-E adapter. Not so sure about USB 4/TB4 if your motherboard does not support.
USB 4.0 is not a must have feature. Wifi 7 is more beneficial over USB 4.0.
That's why it's not a must have feature.
Yep, x870e is actually worse than x670e if you need 2 full speed gen5 ssd.
The USB4 controller in X800 use up one gen5 connection off the cpu.
x670e, you can connect 1gen5x16 gpu + 2gen5x4 ssd, full speed
x870e, if you connect 2gen5x4 ssd, your gpu connection drops to gen5x8.
The X670E and X870E actually uses the same chipset (from Asmedia) so the number of PCIe lanes is the same. Take some away for USB4 and there is less left.
nope talking about the pcie lanes provided by am5 cpu. total is 28 gen5 lanes usable
with x670e mobo vendors wired the lanes usually 16 to gpu, 4 + 4 to gen5 nvme, 4 to the asmedia PROM21 chipset
with x870e mobo now wired to 16 gpu, 4 to gen5 nvme, 4 to asmedia ASM4242 usb4 chipset, 4 to the asemedia PROM21 chipset
but both asm4242 and prom21 are wired as gen4.
mobo will want offer 3 or more nvme slots selling points but the dedicated pcie lanes are limited
