iPhone 16e/Plus/Pro/ProMax Discussions [No WTB/WTS/Flip]
What color are you buying?
  • iPhone 16/16 Plus (White)
  • iPhone 16/16 Plus (Green)
  • iPhone 16/16 Plus (Pink)
  • iPhone 16/16 Plus (Blue)
  • iPhone 16 Pro/16 Pro Max (Black)
  • iPhone 16 Pro/16 Pro Max (White)
  • iPhone 16 Pro/16 Pro Max (Natural)
  • iPhone 16 Pro/16 Pro Max (Gold)
kashix
I ran the i4.cn tool and found that my IP16PM panel serial number starts with G9P. Is that supposed to be a good panel model?
Manufacturers:
  • G9N: Made by Samsung, this is the highest-quality screen used in the iPhone 13 lineup. It offers superior clarity, color accuracy, and durability.
  • G9Q: Also from Samsung, this is a second-tier screen. While still good, it doesn’t quite match the G9N in terms of overall quality.
  • GVC: This is LG’s best screen, but it ranks as a third-class screen compared to Samsung’s G9N and G9Q.
  • G9P: Another Samsung-manufactured screen, this fourth-tier display has lower quality control standards, making it less reliable.
  • GH3: Manufactured by LG, this fifth-class screen is the lowest in the lineup. It’s less durable and has poorer color accuracy.
This is what I found
SeanPC
I thought ip16pm is using Samsung series 14 screen which is better than series 13. This grading is the tier in the 14?
oric1
I tried this method many times but cannot it to generate the sysdiagnose file so I googled and found an easier way to run sysdiagnose using Assistive Touch.
Settings > Accessibility > Touch > AssitiveTouch > on
Settings > Accessibility > Touch > AssitiveTouch > Customize Top Level Menu
... and add new icon for "Analytics"
Now you can run sysdiagnose just by tapping a button on the screen.
How to view the file after I downloaded the PC? Thanks.
szeli
it’s a text file
oric1
it’s a text file
The file is so huge (624MB), text editor can't load the file. Wonder how the rest here managed to view the file. Any help? I just want to know if my panel is from LG or Samsung. Thanks.
kashix
I’m
just open with iOS default Finder can already, nothing hard leh, you even managed to generate the diagnostic file already.
cheryl81
just open with the phone is ok ah.
quite easy
iosnewbie
I think we can soon start a new poll to indicate which model of display panel we have in our iPhone 16s.
