30s-50s chitchat club
Lss
I am planning to install a Xiaomi CCTV outside one of my units, but there are no power sockets and my idea is to connect the CCTV to a powerbank and charge the powerbank using solar panels in the day. Powerbank will be hidden inside a compartment near the roof close to the CCTV. Do anyone have any suggestions?
Suggestion in what aspect?
Sounds good but might not be enough if it's set to always record. How busy is the view?
Lss
Do you install CCTV in your living room when U rent out your room(s)?
I am going to have a lot of comics and CDs in my place but I don't think people will steal these stuff generally 🤔
Later they flip through it how. What comic? 风云 type?
Autumn.
from which country when @Duc_mn jiejie tour mont blanc? i understood that only from france side can "climb" to the top?
currently i cannot see myself going anywhere , my personal kinmen trip got postpone thrice....
Autumn.
I've taken over some of the rental units from my mum, hoping to get some of the things I hope to set up before I start work again in 2025.
Ryan's suggestion by far is the best.
There are other methods, not advisable from Price point unless u want to get more than CCTV automation. such as a semi smart accomodation, while at it, get the electrican to install a spare cabling route for future
@irregardless i too small white ... there is other issues also. que sera .now just savouring my last moments of spare time
@albert.wesker if u worried, then dun get housemate. TBH tenants and housemate also need a bit of luck. some of the things people take can be as simple as a set of cutlery + bowls/plates making your set looks missing
i have lost couple items. one of which rather difficult to replace. That said i have met good people.
wish all a great year ahead. hopefully keep in contact. let goneby be goneby until someone deliberately repeat same old stunts! :crazy:
flowerpalms
Maybe just ur bedroom where you keep ur valuables
Put living room is to check for paranormal activity
Autumn.
actually install yes, but have to tell tenants and have to aim at door only. unless it is own room and yes , can aim all 4 corners
albert.wesker
I'm leaning towards no cameras just want to see it I missed out anything 🥸
highsulphur
Was just joking. It's good you take over some of your parent's responsibility to lessen their burden
aceminer
Commercial or residential? Commercial then can right. Residential I don’t think can?
Duc_mn
Perhaps miscommunication....did the Tour du Mont Blanc trek similar to this
https://www.muchbetteradventures.co...ers-guide-to-trekking-the-tour-du-mont-blanc/
I am not fit enough to climb Mont Blanc :( But yes, France side to summit.
Rest well for body to recover first, there are always opportunities for travels after
TonyDelPiero
