What was the phone you traded in btw?
No trade just using vouchers that I receivedWhat was the phone you traded in btw?
Can't open the link, not found
The requested page could not be found
I just opened it....no issuesThe requested page could not be found
Does the special $200 code start with SL7?I just opened it....no issues
Even the promotion listed only show SC+ & $88 off
That's rightDoes the special $200 code start with SL7?
The code SL7 is for the Samsung care+ right? Not really -200 from the phone itselfThat's right![]()
U r right, they added the SC+ then minus $10, $88 & $200 from the vouchers given...Did you check if the cost price they added $210 for the SC+ and after applying the SC+ code they deducted the $210 off. Could this be the $200 code that you received?
Eg 512gb PO price
2008+210=2218
Before all the discounts
So is just the SC+ freeU r right, they added the SC+ then minus $10, $88 & $200 from the vouchers given...
yes they add the SC+ money inside total cost of your phone to make the "discount value" looks BIGGER!Did you check if the cost price they added $210 for the SC+ and after applying the SC+ code they deducted the $210 off. Could this be the $200 code that you received?
Eg 512gb PO price
2008+210=2218
Ya lor.....yes they add the SC+ money inside total cost of your phone to make the "discount value" looks BIGGER!![]()
did you try the HUAT38 code? I think still valid with 10% first timer for in-app purchase and shopback.U r right, they added the SC+ then minus $10, $88 & $200 from the vouchers given...
