dredd
- May 13, 2002
I put mine under adaptiveDid you guys configure the battery protection to basic or adaptive?
separate email in 3-4 dayssomehow i feel s25u is so much nicer to hold and use as compared to the now heavy s24u haha
sorry quick question too
should i be receiving any separate email for activating the samsung care or its automatic?
adaptive modeDid you guys configure the battery protection to basic or adaptive?
Router is 4x4 but I think S25 Ultra only 2x22x2 or 4x4 stream?
When you paid for the phone the price is already stated there. Probably compasia wont know the breakdown in their system / email.I received the email from compasia to acknowledge the trade-in.
However, under the "overtrade", it states as $0
"Overtrade value (if any): SGD 0"
Is this normal? Or the $180 overtrade is from Samsung and is considered separate?
You hooted also uh crow bro, how are you!Not sure if this has been shared but if you order using SAFRA promo got 25% off (better than 10% off samsung shop app) https://www.safra.sg/promotions/samsung-galaxyS25
Also checkout with Promo code <EPPVIPQ1> to enjoy free 2-year Samsung Care+
Like the preorder promos, this one only avail until 13 Feb 11:59PM.
Honestly pretty insane![]()
normally i verify my deep sleep and sleeping apps and remove or add manuallyHmm, after 3 days of learning usage pattern, it's finally done. But projected to last only 10 hours. not sure if i need to re-setup the phone again.
hmm, added every app i dont use freq in there liao. maybe i need to remove and add again.normally i verify my deep sleep and sleeping apps and remove or add manually
I always on basic. Good enough for me as I do not leave it to charge overnight.Did you guys configure the battery protection to basic or adaptive?
trying to match the theme of a yellow watch...
your ultra? mine shows full charge last 1 dayhmm, added every app i dont use freq in there liao. maybe i need to remove and add again.
Maximum.Did you guys configure the battery protection to basic or adaptive?
ya ultra. 10 hours only for me.your ultra? mine shows full charge last 1 day
Okay thanks for the info!Yes. The counter staff gladly helped me made an appointment. She also noted mine is a brand new phone, SC+ might not be activated. So she told me, she will do the manual process to validate.
Shall see. Appointment is tomorrow evening...
The one you used when making your PO lorLucky draw is asking for evoucher code, which code is that? Thanks.
Swee sia thanks for sharing this dealNot sure if this has been shared but if you order using SAFRA promo got 25% off (better than 10% off samsung shop app) https://www.safra.sg/promotions/samsung-galaxyS25
