KakiMeow
- Feb 11, 2025
tis one 40 yr ago lo ...
... still track lecord veh good
other pples few year one time ijjit
Most bto projects are china and local joint venture.
So how?
I had experienced tremor in the first year of moving into the current flat@1982-1994 chu worry? High floors.
Hope HDB and BSC do their job properly. They are being paid to ensure everything is in order and to sell us the “lease” of 99 years of the HDB for 6 digits figure so we as buyers expect certain level of professionalism from them and the quality of the building they assign the construction firm to built.Singapore has no earthquake. So, it's easier to get away when developers try to get away with cheap materials, poor workmanship to cut cost.
I hope this never ever happens to a HDB building. If it does, the consequences will be very very serious. Nowadays, our HDB building are much taller than old days. More people will die if buildings collapse.
When I passed by construction sites, the rebars used in the construction are rusty. Over time these rusty rebars will become brittle, weakening the structure.If not designed to withstand severe earthquake means it will collapse if at epicenter of 7.7, but will still withstand a lower magnitude
Depends on how much the building sway.If not designed to withstand severe earthquake means it will collapse if at epicenter of 7.7, but will still withstand a lower magnitude
Rust is cosmetic. It actually helps the bonding in a pour. Oxidation ceases once encased in concrete.When I passed by construction sites, the rebars used in the construction are rusty. Over time these rusty rebars will become brittle, weakening the structure.
Or hdb painted these rebars brown?
This is why i avoid tiong developers at all cost...can't be trusted.
It is well known concrete bond better with rusted steel. Alkaline condition in wet concrete and harderned concrete will chemically convert the rust and protect the steel from rusting.When I passed by construction sites, the rebars used in the construction are rusty. Over time these rusty rebars will become brittle, weakening the structure.
How about those built on hill-locks like havelock hillside ?Desmond will create a new cat of HDB liao. Its under Ultra Prime, MOP will be 15 years, whole project guaranteed non Chinese, from Dresign till fixtures and high earthquake resistance. Ultra of course come with a premium price, and must wait longer as non chinese contractors usually slow slow one. Project will be situated on those location with granite underground.
Go buyers for these ultras boh?
HDB flat projects the construction contractor is just responsible for building. The architect, structural designer, m&E designer, site inspection, lab testing all by other companies.Hope HDB and BSC do their job properly. They are being paid to ensure everything is in order and to sell us the “lease” of 99 years of the HDB for 6 digits figure so we as buyers expect certain level of professionalism from them and the quality of the building they assign the construction firm to built.
Don’t expect limpeh pay 6 figures still consider: “pay peanuts get monkey” type of HDB flat.
Cos when bbfa mentality is always ad hominem argumentsWe have bca.
Why is every1 so ignorant here ?
HDB precast structural components are joined using steel rebar splices and cement grout. If the steel rebar splice length designed long enough or mechanically interlock rebar splice can withstand earthquake and no much different from cast in situ.Even hdb trying cost cutting ways to maximise profits. Jungle land that was at no cost of land acquisition compensation yet charge so high.
I still trust the old construction method, slow but sturdy. Look at those old colonial buildings, almost a 100 years and still standing strong.
Those lego like BTO construction, I suspect some hard shaking will dislodge or break the bolts holding them down. Once the pieces are out of place, we'll see a repeat of the Thai building.
