Starhub UltraSpeed 3Gbps/5Gbps/10Gbps plans
There's a group buy on the ONR
[BACK BY POPULAR DEMAND] StarHub 5Gbps Home Broadband Promo at $29.55 monthly only!
24months contract
- Includes 1 Free Nokia ONR Wifi 6 Router and Nokia Beacon 2 mesh
- 12months free of
Asian + tv package https://www.starhub.com/personal/tvplus/passes/asianplus.html
OR
Entertainment + tv package
https://www.starhub.com/personal/tvplus/passes.html.
Installation and set up is free of charge!
No other hidden charges!
Fill in your details in this Google form for those who are interested in either of the plans!
Starhub will reach out to you directly within 3 working days upon receiving your interest!
Sign up link 👇
https://forms.gle/cDEy6G83sZXoNw5SA
Host name : mayling lbkt
Pricing is good.
But for those who do not have LAN ports in the rooms and have to use Wireless Backhaul, I strongly recommend you to give up on this plan. You will most likely regret later with the poor WiFi coverage or unstable WiFi.
Starhub may be less likely to entertain your request to change the Nokia ONR to ONT with this kind of special offer.
Just my personal opinion.
habibali
Hi my beloved friends! My Starhub 5gbps is up and running! Thanks all and Thanks to Selina as well hehe.
Will be selling my HB710. anyone keen :D
cstanhwz
Can't seem to find any option to disable.
Have tried Auto for both channel and width, fixed channel + auto width, fixed channel fixed width, but didn't seem to help my issue
Edit to add: Band Steering is off. Did some more research and am going to try fixed 80Mhz on Ch149 to monitor if the issue persists. Maybe it is due to DFS since previously I had fixed at 160Mhz, and auto usually goes 160Mhz too.
You can try to set a fixed channel and try first. Eg Ch 40 for 5GHz.
Channel bandwidth should be not related to your issue.
Henry Ng
Pricing is good.
This Nokia ONR is known to have network issue so better give up. I was using it earlier.
habibali
You got your own 10Gbps router? If got ASUS then very good.
using the old AX86U lol. working well with WAN 2.5gbps wireless. maybe next year get a proper 10gbps router. :D or you can blanja me one... i will be very happy!
Henry Ng
Like that you can not really enjoy the faster speed. Now i use EB810v is super fast.
doreen27
just recon to the 3gbps 29.55 plan..
they have provided with the TP link HB410
any one have any idea what’s the default password for 192.168.0.1 ?
I'm Newbie 2023
HI everyone, also recently signup the 3Gbps plan with HB410. Do you all set the 2.4Ghz and 5Ghz separately or combine 2.4G & 5Ghz. Which is better in term of connectivity? And most home use security camera/IP camera still need 2.4Ghz instead of 5Ghz
Also, will getting HB710 and mesh with HB410 get better speed and coverage for this 3Gbps plan as HB410 only 2.5g lan/wan?
babyjyo
- Normally, i would have one combined and one only for 2.4ghz. But, if your wireless is simply strong, you could just have dedicated 5ghz and 2.4ghz.
- it on your house layout and whether there is enough coverage. 5ghz generally gets weaken very easily by walls and objects, while 2.4ghz is able to reach out broader.
- there are still a lot of IoT, cameras, etc still only recognising 2.4ghz.
Henry Ng
somehow my iphone 16 pro max only 700mbps download \ upload and laptops... xiaomi fones 200mbps.... hmmm...
Understand that some mobile the processor is not fast enough and the wifi adaptor also not so good. Usually for Laptop with power adaptor, you can get 1500 Mbps and for mobile phone is 900+ mbps.
HiHelloBye
best practice is to separate two networks...
meaning to say, disable band-steering
cater the 2.4Ghz for Smart Appliances such as IP Camera, Smart Vacuum, etc
cater the 5Ghz for End Devices such as Laptops, Smartphones...
sglandscape
Any reason for this recommendation? As far as I'm aware, if supported best to have a single SSID and allow your device to roam and decide which to connect to.
For IOT devices, if your access point supports it, create a seperate SSID, and put it on a seperate VLAN for better security so you have truly two seperate network.
manofsorrows
if you put iot devices on a separate ssid (with same subnet), will your phone that controls those iot devices need to be in the same ssid as the iot devices ? means have to switch back and forth ?
sglandscape
Suggestion is to use a different VLAN and different subnet to have isolation. Your router can route between the subnets, so no need to switch back and forth?
