developer bought the land at $4.4m, if they manage to clear both units at $4.5m each, still got $1m plus profit after taxes and construction costs, not too baddeveloper must be desperate to offload
so fast reaching the penalty?developer must be desperate to offload
yeah still good profitdeveloper bought the land at $4.4m, if they manage to clear both units at $4.5m each, still got $1m plus profit after taxes and construction costs, not too bad
- Price: S$5,200,000
- Property Size: 2391 sqft
- Land Size: 2166 sqft
- 5+ Bedrooms, 5 Baths
The build-up looks weird. Already super small still go put in a big car porch.
Buy already very hard to offload in future. In a way, worst than those facing mainroad (at least those are quantum play and can rebuild).
Exactly... there is some value in it.car porch size seems to be standard size based on URA minimum requirements for setback.
2391sqf is about a corner terrace size
actually for $4.5M, it is quite a good price for a brand new house. even if own-self buy an old corner terrace and rebuilt today will likely cost more than $4.5M
what's the land size that the gate can't close?Hi all, i am currently looking at the thomson garden area landed ( the jalan hari raya, pintau, chegar etc..). Location seems solid with it 1km within 2 branded primary school, near shunfu market/hawker and the nearby HDB amenities (coffee shop, clinic etc..), walkable to mrt and busstop ... also it is a 3 storey landed zone
Below 4.5mil seems to be able to get a decent condition terrace for a family of 5. (with minor works probabbly)
however, i noticed most of the land there are small sizes. if park a continental car, most of the gates cant close. and while 4.5mil quantum is palatable in today market.. it also means the psf are like 2500psf above. (condo psf)
Do you guys think is a good buy still in this area? or i should start looking at other areas with 4.5mil budget.
ps: i try looking at other landed enclaves but either they are not near mrt/bus stops or not near amenities or very original condition..
or maybe i should just go for 5 bedroom condo instead with my limited budget? hahaha
think some of the house there land size less than 900sqfwhat's the land size that the gate can't close?
if you can get a house with a bigger plot of land for the same amount of money, why do you want to get one with a smaller plot size?been to a few around there ranging from 900sqft to 1700sqft... most cant fit a car fully in.. though agent say outside can also park 2nd car since no lines..
will that be hard to sell next time? like a strict no go to most buyers? or just a small pain point?
also, may i ask same building condition and same land size, should corner terrace psf be worth less than inter terrace since build up area is smaller?
Its quite unlikely that the gate can’t close if park conti car unless the house is on a raise ground i.e. few steps up to the house?Hi all, i am currently looking at the thomson garden area landed ( the jalan hari raya, pintau, chegar etc..). Location seems solid with it 1km within 2 branded primary school, near shunfu market/hawker and the nearby HDB amenities (coffee shop, clinic etc..), walkable to mrt and busstop ... also it is a 3 storey landed zone
Hypotheticallyif you can get a house with a bigger plot of land for the same amount of money, why do you want to get one with a smaller plot size?
while there will be buyers for these houses with smaller plot sizes, the pool will likely be smaller.
a corner terrace is basically a semi-d house so technically it is better than an inter-terrace. of cos if comparing based on same plot size, the built up area for a corner terrace will be smaller due to the size set back but you get better ventilation and more natural lighting compared to an inter-terrace
Hypothetically
1) smaller land size but move in condition with 2.5 storey structure corner terrace (park half a car) VS
2) slightly more original with 2 storey bigger land size inter terrace.. (can park 1 car nicely)
both roughly around the 4.5mil mark around same vincinity.
i will have thought option 1 easier to exit in future since most ppl prefer hassle free move in.. then to do a gut reno. plus small land size= lower quantum then higher pool of demand also ( cause 4.2 vs 4.5m may make a difference to most ppl?)
between the 2 option, which u will prefer personally?
You can provide exact land size or the difference in land size?Hypothetically
If your new enclosed area is between your building and the set back line (2m from boundary line) then should be ok. Note that any wall (constructed using glass or brick) must still adhere to the 2m set back from the boundary though you still can have a 1m extension from this new wall into the set back areaHi guys, I’ve been musing about how to utilise the outdoor space in my irregular plot and have got a couple of questions: if I were to build a legal glass canopy (respecting the setback boundaries) on the ground floor am I allowed to:
1. Build glass curtains/iglass along its boundaries?
2. Build an air-conditioning unit within the canopy?
Thanks in advance!
