MARI invest
peppermint7
oh, i dont know abt this promo. i dont spend $300 anyway...
I think I'll just go buy NTUC gc. Or you can also buy Sheng Siong gc. I heard Sheng Siong gc doesn't have expiry date. You can slowly slowly use. Provided you are still within 30 days from opening. Free $30 why not?
I just sign up. Wah not bad. Still can get $12 off on Shopee. Thanks for the heads up @wutawa ♥️
alanchia67
correct me if i am wrong. u will get slighly more payout in jul than in jun since u reinvest right? otherwise your payout should be roughly same.
Yup will be slightly more payout. Since I do not need the income as yet, I may as well buy more units (however small they are) and continue till I am retired (which is soon, I hope).
geographic
they gave 6X this week cos they heard you
The Fund Managers need to work hard; otherwise, they will face the harsh reality of investors withdrawing their funds for better options. I just purchased FWD Series 7 policies at 2.6% p.a. for maturity in two years, with my GXS funds that have matured. GXS is currently offering 1.98%.
white_prince
1.98% not bad but your FWD save smart series is better…it has been fully subscribed
alanchia67
What has been the payout for income? Is it anywhere close to the 6.6% they listed?
It depends on the NAV when you purchase. Right now the NAV is rather high. Those who bought earlier at lower rate have profited.
By the way, the 6+% is since inception. It's different from payout rate which is about 4.5% now.
sp0inK
thinking to transfer from invest to income. the next payout date is end of july. i should just hold until a few days then buy a few days before the payout date?
alanchia67
If you are really concerned, you may as well monitor the PIMCO NAV before buying. Yes the payout is not pro-rated, but the NAV will determine how many units you can buy and will directly impact how much payout you'll get.
And of course will impact future market value (when the NAV increases or decreases). The current NAV of 9.49 is a little high.
silentears
can check mari invest save plus
why are some the days 0 returns? is it because no changes to the NAV?
then the next day will be double returns?
recalled that was a post for this previously on mon- to fri which day got interest in
thanks
alanchia67
thanks
Yes the Interest is determined by the NAV. Just like other Unit Trusts, there will be days the NAV is unchanged.
wutawa
thanks
Saveplus is an investment, returns not guaranteed. The daily returns can be positive, zero, or even negative. Getting zero doesn't mean the next day will double. Tue and PH(+2 business days) usually has more returns.
https://www.maribank.sg/help-centre...y-return-on-weekends-for-mari-invest-saveplus
