Nope, none of the ST MVNO supports VoWifi on any device at this point.GOMO don’t seem to support VoWiFi despite iPhone setting toggle on Wi-Fi calling.
Oh, hope it’s coming soon to fully support VoNR and VoWiFi when SingTel unleash the lock on all these MVNO.Nope, none of the ST MVNO supports VoWifi on any device at this point.
Only works on Singtel's own plans.
VoNR is very likely.Oh, hope it’s coming soon to fully support VoNR and VoWiFi when SingTel unleash the lock on all these MVNO.
Let's hope one day this toggle option will suddenly appear for those under Singtel networkVoNR is very likely.
For VoWifi, the chance is slim IMO.
Is this an iCloud Shortcut? The background looks like the Shortcut app with the tiles.
Yes see my previous reply ^Not on android but ios shows some info on *3001#12345#*
Found a shortcut that shows its still 5G NSA: https://www.icloud.com/shortcuts/c85ac02853bd42e692a5589de78665da
actually SingTel 3G is still running healthy today!Some said GOMO yellow app is 5G SA, anyway IMDA requires all 5G networks in Singapore to move to the SA version and phase out NSA support by December 31, 2025.
2G Shutdown, 3G Shutdown
5G NSA to be shutdown by 31 Dec unless there is changes.
What is available will be 4G and 5G SA.
It seems like M1 is already on 5G SA only, if I disable 5G SA, it drops down to 4G, not 5G NSA.As for a pure-SA NR network, I doubt it is doable.
SA roaming is very hard to do. NR uses a different encryption and authentication method than LTE. That's why when you travel and do a 5G roaming, you are mostly always on NSA.
Like China, in about 2022, the country was SA only. But more tourist came in 2023, 2024, and they couldn't connect to 5G roaming. So China re-opened NSA for those roaming use.
If Singapore turns to SA only, will be not so good for incoming travellers.
both UARFCN 3088 (900MHz) and 10613 (2100MHz) are still running
There are still some credit card POS machines running on 3G that I've seen.
Plus, when there is no SIM card in a phone, in order to call emergency service, 3G is still required! Even if VoLTE is supported, that requires a SIM card. VoLTE for Emergency Service is another different techonology, and I believe this is the reason Singaproe still can't give up 3G
also the most concerning might be unable to call emergency without 3G.Yes because some dinosaur infrastructure is still using them, our dear stat boards are one of them, they are slowly migrating it over to 4G. These are usually POS and "Sensors" for public infra, I can't say what those are, as I manage few of these.
Just change my zero1 to prefer 3G and sure enough, it is on 3Gactually SingTel 3G is still running healthy today!
Just change my zero1 to prefer 3G and sure enough, it is on 3G![]()
3G tower : Ban anything that can connected to 5G SAInteresting.
This is not working for my Poco X7 Pro with Singtel S$15.28 per month SIM Only Plus plan.
Prefer 5G -- 5G SA, showing 5G+ icon
Prefer LTE -- 4G LTE, showing 4G+ icon
Prefer 3G -- no network, showing "no network" icon.
Agreed, the ultimate delay is the government sector.Yes because some dinosaur infrastructure is still using them, our dear stat boards are one of them, they are slowly migrating it over to 4G. These are usually POS and "Sensors" for public infra, I can't say what those are, as I manage few of these.
Or perhaps, ban 5G SIM cards from connecting.
Probably enough for basic usage still, and if it works for voice call/sms, can allow one to be contactable.This morning, I took out the old 3G SIM Card which came with my Singtel Fibre Internet sign-up in Feb 2012 today and tested with an old Prolink 3G HSPA portable hotspot No connection either.
My wife was using the portable hotspot last time as she was using StarHub Prepaid. It has not been used since 2018.
I went to Singtel Shop to exchange the 3G SIM card in the afternoon. Initially I tried the kiosk but it did not work (it worked for our other Singtel SIM cards, including two postpaid and one prepaid card). Then I went inside the shop to get the staff to help to exchange to a new 5G SIM Card. The free 1GB 4G data bundle is probably useless though.
50% Off PromoAny GOMO 5G promo code? Am using M1 maxx 5G SA plan now. The speed is undesirable and want to make a switch soon.![]()
Wait for 11.11 promo.50% Off Promo
Enjoy 50% off for 1 month on our 5G+ Value plan! Simply apply the promo code <VALUE50> before you checkout on the order summary page. Valid till 5 Nov 2025. View T&Cs.
Only 1 promotion i can find..
