Full_Cream_Milk
- Jan 22, 2018
Edmw people drink 3-in-1
Please close thread.
Could you explain the reason for the grinder over the machine? I heard a lot online about it too.
I have a separate delonghi espresso standalone coffee machine and a separate delonghi coffee grinder which i use previously and i've kept it in my store room after i got a fully automatic machine.
Got the fully automatic machine because my parents do not know how to operate these machines manually, so i decided to get a fully automatic one which is easier.
I've been deciding to bring out my delonghi espresso machine / separate grinder back out again for my use.
The rule-of-thumb is supposed to be, that the higher the altitude, the higher the acidity … and by region:I just msg Soji about restock for Brazil Maritaca Santos and the reply is it is oos and will not be restocked anytime soon. They rec me to try Brazil Santa Maria Cerrado as it has a similar roast profile. Have tried Soji Sul De Minas and did not like it as much compared to Maritaca Santos as it was more bitter and roasted darker for my liking.
and what I recall Cerrado was slightly higher than Santos.
I’d probably have to look at 1 of the M’sia roasters if they don’t want to make Santos available in at least 500g bags.I see thanks.Grind consistency gives less cup to cup fluctuations, and when dialing a batch of different beans the last thing is to have systemic variability despite tweaking only single parameters.
A decent machine basically distribute hot pressurized steam over the (puck).
Agree super automatics are great for less saavy folks who just wants an espresso based coffee drink.
Took me quite a while previously to switch my waifu from Nespresso pods to a grinder / espresso machine setup, until I moved the Nespresso machine to office![]()
Thank you. I've tried Santos and it's not bad. But recently, I've switched to Yunnan Bao Shan coffee beans.The rule-of-thumb is supposed to be, that the higher the altitude, the higher the acidity … and by region:
Somehow, Santos was the best for me, although I guess Sul De Minas is (now) a compromise I can accept, having had Sul De Minas from both Zero and Soji before.
- Santos: 800 - 1,300
- Cerrado: 900 - 1,300
- Sul De Minas: 900 - 1,200
Cerrado I haven’t tried so I can’t say for sure, but @Apparatus has this acidity tester thing he’d stick into his coffeeand what I recall Cerrado was slightly higher than Santos.
I don’t know what’s the deal with Soji … that 200g bag of Maritaca Santos I bought was also “last bag” … buy already very fast another “last bag” of 200g became availableI’d probably have to look at 1 of the M’sia roasters if they don’t want to make Santos available in at least 500g bags.
The thing about superautomatic - and why I retired mine - is that, you really need to manage your expectations, especially when it comes to cleanliness / hygiene.Agree super automatics are great for less saavy folks who just wants an espresso based coffee drink.
True make sense. That is why for my super automatic, I always air dry after drinking my daily cup in the morning, empty drip tray and empty grounds. Then again in the afternoon coffee. Very mafan also.The thing about superautomatic - and why I retired mine - is that, you really need to manage your expectations, especially when it comes to cleanliness / hygiene.
When the brewgroup ejects the puck into the drip tray box, it is still damp and steaming … if you only want to clear when the Full sensor is triggered, if you are lucky, the pucks are mouldy … if you are not, the internal of your machine also start to build up mould.
After I kenna 1 time because after making my coffee I drink already straight went to work … come home from work I opened up to wash the brewgroup (I always take out and wash before making a coffee), I could see inside walls got mould already. From then on, always after making the coffee I must empty out, wash and dry the drip tray and drip tray box, wash the brewgroup leave it outside to dry … end up the amount of time needed to make a coffee on this superautomatic no different from using an espresso machine with portafilter, so … yeah … if both going to take the same amount of time, might as well choose the option that gives me better coffee, no?![]()
I see thanks.
I got this grinder with me in my storeroom
Is this good?
Last time I use this, but my parents don't know how to do and lazy to do. So in the end, I got super automatic.
I drink owl 2 in 1. Jin nice.Thought it’d be a good idea to have a dedicated thread for those of us who own an espresso machine, i.e. the ones where you use a portafilter, to discuss machine related stuff and beans.
Whether yours comes with an integrated grinder, you have a standalone grinder, or you buy pre-ground, you’re welcome to this group.
As a continuation from @Apparatus ‘ thread, my machine:
After all my issues with my same-OEM-as-the-Smeg superautomatic, I finally took the plunge and got this.
I fell for the Normcore hypeNormcore tamper, Normcore WDT, Normcore steam handle, Normcore bottomless portafilter, Normcore coffee scale … even the Normcore glass tubes to store 18g of beans per tube
Around the time just before I retired the superautomatic, I bought a bag of Soji Brazil Sul De Minas beans … I actually like this more than Zero’s Sul De Minas, although it was not a fair comparison of Zero on the supermatic and Soji on the Breville … I then tried a 200g bag of Soji’s Brazil Maritaca Santos beans and this became my favourite … only problem is Soji seems to have deliberately set the Santos to sold out for the 500g and 1kg options, and limited the stock of 200g to 1 bag in an order.
12.12 I bought back a bag of Zero Sul De Minas, but after the 2 bags of Soji that I started off with on the Breville I can’t seem to dial the Zero in right … on the Normcore bottomless portafilter I get a 40something g shot in like 25 seconds, and on the stock Breville portafilter using single-wall basket I get a 30-31 g shot in like 40something seconds … same grind size for both.
And I still can’t get latte-art consistency with my frother … it’s always super-frothy capuccino consistency or not micro-foam-y enough, never in between
Any other Breville or other espresso machine owners care to share your experiences? @Jurong640 @randyap @menthol28 @rrr2015 @dxdx999
Spot on !For me I find that a good grinder matter the most then the expresso machine..
Problem with pods / capsules is you will never know exactly what they put into themGrind consistency gives less cup to cup fluctuations, and when dialing a batch of different beans the last thing is to have systemic variability despite tweaking only single parameters.
Can always sacrifice one pod to see what is inside.Problem with pods / capsules is you will never know exactly what they put into themNot even certain if it’s just coffee …and no fillers
tried so many times before. Can’t identify one unless send for lab analysis. Then there’s freshness of the ground regardless of vacuum sealing. Also 7g of coffee in each pod will never make a proper espresso.Can always sacrifice one pod to see what is inside.
Those pods are great in marketing "premium" coffee, for convenience over 3 in 1. Charge a high price.tried so many times before. Can’t identify one unless send for lab analysis. Then there’s freshness of the ground regardless of vacuum sealing. Also 7g of coffee in each pod will never make a proper espresso.
bean to cup is the way to go. Where capsules score is the sheer convenience for a quick grab and dash.
