Absolutely — ancient Roman design is a fascinating case study in
passive cooling and climate adaptation. While Liu Thai Ker’s concrete-heavy approach in Singapore amplified the Urban Heat Island effect, Roman builders often integrated cooling strategies directly into their architecture and urban layouts.
Cooling Features in Roman Design
- Aqueducts & Fountains
- Water was central to Roman cities. Aqueducts supplied public fountains and baths, which not only provided drinking water but also cooled the surrounding air through evaporation.
- Piazza fountains acted like natural “air conditioners” in open spaces.
- Thermal Mass & Thick Walls
- Roman buildings used stone, brick, and concrete with high thermal mass, absorbing heat during the day and releasing it slowly at night.
- This stabilized indoor temperatures, reducing extremes.
- Atriums & Courtyards
- Houses (domus) often had open-air courtyards with shaded colonnades.
- These spaces promoted airflow and created cooler microclimates inside homes.
- Orientation & Ventilation
- Roman architects carefully oriented buildings to maximize shade and cross-ventilation.
- Windows and openings were strategically placed to channel breezes.
- Baths & Cooling Pools
- Public baths (thermae) weren’t just for hygiene — cold pools (frigidarium) offered relief from heat.
- Their large halls with vaulted ceilings also encouraged air circulation.
- Urban Layout
- Roman streets were often narrow and shaded, reducing direct solar exposure.
- Arcades and porticos provided shaded walkways for pedestrians.
Lessons for Modern Cities
- Romans understood that water, shade, and airflow were essential for livability in hot climates.
- Modern planners in Singapore and elsewhere are rediscovering these principles — integrating green corridors, water features, and shaded walkways to counteract UHI.
- In a way, Rome’s passive cooling strategies anticipated today’s climate-resilient urban design.
Would you like me to
compare Roman cooling strategies with Singapore’s current Green Plan 2030 measures (like tree canopy expansion and park connectors)? That would show how ancient wisdom and modern sustainability converge.
Never consider people, his designs only squeeze more people and completely ignore comfort. Terrible in his job really
