Aladdin Beast
- Jul 21, 2019
And get forever reject?just chat with cso on whatsapp ask them about the promo u see online, if still reject ask them transfer to another team
they got different team/ department that have better offers which are the ones posted here. the first line usually is the standard lousy promo. need ask them to transfer.And get forever reject?
Good luck. Seems like only after contract end then got chance.they got different team/ department that have better offers which are the ones posted here. the first line usually is the standard lousy promo. need ask them to transfer.
not true. a lot here did it after 21st month.Good luck. Seems like only after contract end then got chance.
Not sure. Sunset80 3 days left still no chance. And is an upgrade case, not downgrade. Anyway, such things let user share. If you day after 21 month also cannot true. a lot here did it after 21st month.
that's why i'm sharing here..? not sure what you meant.Not sure. Sunset80 3 days left still no chance. And is an upgrade case, not downgrade. Anyway, such things let user share. If you day after 21 month also can
They only offer me the $29.90 promo after I sent in my termination request. By then is already too late as I already jump ship to the green side.My 1gbps contract is ending in 3 days time but Singtel still refuses to give me that promotion.![]()
I got a call from SingTel who offer me $49.90 for 3 Gbps. Crazy price. i told them I will consider to terminate after contract end. They say they will check for better offer and call me back.
After talking to the them after saying I consider to terminate, this is what they offer me
3GB Enhance (Wifi 7 HB611) @ $39.90/mthly - 24 mths ct (U.P. $73.90) ($50 Fairprice Voucher) With 1 unit of TP link router HB611
3GB Mesh (Wifi 7 HB611) @ $39.70/mthly - 24 mths ct (U.P. $73.90) ($50 Fairprice Voucher) With 2 units of TP link router HB611
I got until May to consider. Hope there is other offer soon.
Singtel speedtest server seems like fixed alrJust some more testing results. As of now, Singtel Speedtest server is not working properly.
I am using Singtel 5Gbps plan.
Bash:root@openwrt18:~/ookla# ./speedtest -s 13623 Speedtest by Ookla Server: Singtel - Singapore (id: 13623) ISP: Singtel, Singtel Broadband Idle Latency: 0.97 ms (jitter: 0.07ms, low: 0.84ms, high: 1.02ms) Download: 1482.68 Mbps (data used: 1.9 GB) 1.50 ms (jitter: 0.25ms, low: 1.09ms, high: 2.74ms) Upload: 3756.83 Mbps (data used: 6.2 GB) 4.29 ms (jitter: 1.51ms, low: 0.94ms, high: 9.49ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/c4df7b7a-c4a3-4e00-9253-7640ce0ed776 root@openwrt18:~/ookla# ./speedtest -s 62020 Speedtest by Ookla Server: Axclusive Pte Ltd - Singapore (id: 62020) ISP: Singtel, Singtel Broadband Idle Latency: 2.51 ms (jitter: 0.22ms, low: 2.33ms, high: 2.64ms) Download: 5351.16 Mbps (data used: 2.5 GB) 1.79 ms (jitter: 0.31ms, low: 1.47ms, high: 4.83ms) Upload: 4939.27 Mbps (data used: 2.3 GB) 8.48 ms (jitter: 0.65ms, low: 2.68ms, high: 9.48ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/8c7b0841-b36c-4089-a996-177221a30110 root@openwrt18:~/ookla# ./speedtest -s 12687 Speedtest by Ookla Server: SIMBA Telecom - Singapore (id: 12687) ISP: Singtel, Singtel Broadband Idle Latency: 3.62 ms (jitter: 0.38ms, low: 3.31ms, high: 4.04ms) Download: 5409.78 Mbps (data used: 4.2 GB) 3.56 ms (jitter: 0.34ms, low: 3.11ms, high: 5.79ms) Upload: 4934.50 Mbps (data used: 2.5 GB) 9.24 ms (jitter: 0.98ms, low: 3.02ms, high: 11.07ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/ae70a8d8-a943-48d2-9a2c-03203e9556d6 root@openwrt18:~/ookla# ./speedtest -s 5935 Speedtest by Ookla Server: MyRepublic Singapore - Singapore (id: 5935) ISP: Singtel, Singtel Broadband Idle Latency: 2.50 ms (jitter: 0.10ms, low: 2.38ms, high: 2.62ms) Download: 5438.81 Mbps (data used: 4.7 GB) 2.65 ms (jitter: 0.26ms, low: 2.24ms, high: 4.92ms) Upload: 4938.55 Mbps (data used: 2.3 GB) 9.29 ms (jitter: 1.21ms, low: 2.75ms, high: 10.25ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/3136a623-34b7-49ff-b654-45f7c79c79eb root@openwrt18:~/ookla# ./speedtest -s 2054 Speedtest by Ookla Server: ViewQwest - Singapore (id: 2054) ISP: Singtel, Singtel Broadband Idle Latency: 3.87 ms (jitter: 0.53ms, low: 3.49ms, high: 4.99ms) Download: 5439.05 Mbps (data used: 4.9 GB) 3.14 ms (jitter: 0.30ms, low: 2.79ms, high: 5.20ms) Upload: 4936.15 Mbps (data used: 2.4 GB) 9.74 ms (jitter: 0.78ms, low: 4.46ms, high: 11.16ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/909fcd1e-7e58-4dd8-ae62-574c25d4ddb2
i just upgraded to 3gbps to be installed in march. the plan only provides one HB611. If i want to add another to extend my range which would be better to buy?
1) HB611
2) HB710 - but unsure if can work with singtel HB611
3) BE230
Alright i think i will play it safeIn this case, it is better to go with HB611-SGST to play safe.
root@openwrt18:~# ./ookla/speedtest -s 13623
Speedtest by Ookla
Idle Latency: 2.01 ms (jitter: 0.09ms, low: 1.79ms, high: 2.15ms)
Download: 5538.97 Mbps (data used: 2.8 GB)
12.95 ms (jitter: 1.67ms, low: 2.03ms, high: 17.99ms)
Upload: 4938.15 Mbps (data used: 2.2 GB)
7.73 ms (jitter: 0.75ms, low: 1.43ms, high: 9.06ms)
Packet Loss: 0.0%
Result URL: https://www.speedtest.net/result/c/075014e6-edd1-4ba3-9256-2db2593e5062
