Samsung Galaxy S2: Troubleshooting (Post your issues here)
ryan_khoo
Details of my set:
Rooted: No
Build Number: Gingerbread.XWKF1
Provider: Singtel
when I goto Phone > Log, it displays all the log for incoming & outgoing for phone calls, sms & emails.
How to I filter just to see incoming/outgoing/missed calls ?
Thanks
Retinaburn1
seems like it's quite a common prob after all.
On singtel btw. happens just about anywhere but more on the train, even if not in the tunnel. pretty irritated by it
Sama sama here
Provider: StarHub. In Raffles Place area n places with poor coverage.
Will show 3G but with no colors on the up/down arrows. Hence unable to surf or open apps which need connections.
Have to on/off the set.
Super sian.
GreenHorn
For this problem, i just manually set to WCDMA connection. So that it doesn't auto switch between 2G and 3G, and of cos you may lost some connections provided that area has very weak 3G signals.
Vulpix
Moderator
Moderator
yes but there alot of different version like XWKE7, UHKE4 XXKE4, i wonder which one is better? sorry just buy the phone here newbie :s13:
If you want to flash different firmware, I recommend that you check out the root thread, as there is ongoing discussion about that. This is more for people who have hair-tearing issues.
halocast
Hi all was wondering hor.. the phone contacts read from the phone or your sim card?
any way to change the option?
nvm problem solved :o
Red8310
Hi hi,
Mine is stock. Something so puzzle.
Yesterday transfer *.mkv movie into my phone. It can be played. Played a few times. Thinking can watch on the way to work or when free.Today I go and play the movie. It says not supported.
Also I download arcmedia for rmvb file. Yesterday can play but sound quality is bad so uninstall the arcmedia. Today I reinstall also cannot play rmvb. Dunno where went wrong.
halocast
Hi hi,
You using default player to play? :s11:
Red8310
Sorry abit off. Instead asking about rmvb. Actually our default player can play mkv right?
wweixian
Rooted: Yes
Firmware: Android 2.3.4 Lite'ning rom with KG 1
Provider: M1
Issue you are facing :
I tried to open the default email application that comes with the SGS2. It will force close on me everytime i refresh my email.
kennyboy
Rooted: Yes
Provider: M1
Known problem for Lite'ning that can be solved if you READ the thread for that rom.
raindropzz
Hi, i'm also trying to figure out how then can i can read/save my contacts from/to the sim card.
Can you help me pls?
halocast
u can import/export from/to the sim card :o
open yr contacts page and press the button beside the home button :o
MarineX
Rooted: No
Firmware: KF1
Provider: Starhub
Issue you are facing: screen sometimes don't go to sleep
