The Galaxy Tab 10.1 thread, or woah this tablet is light!
stanhzb
Foc cos under warranty
Hey, I'm encountering the same issue here. There's a sticker supplied by the micro Sim adaptor to hold the Sim and adaptor tgt. The sticker came off while inserting and the Sim card is stucked. Anyways to remove it?
penmania
I'm using dataflex too.IIRC, they have a shop at amk hub.alternatively, go down to their factory at ubi.
http://www.dataflex.com.sg/contact.html
used to love their film but recently the workmanship and the quality. i just got my friend's laptop and my tab 10.1 got filmed up. guess what i got. full of dots end up with excuses that it will go away a few days. crappy excuses.
dun waste money on dataflex just for SGP will do!
The_Flash
where's the best place to get SGP protectors?
Tuakong
Try to remove yourself but if the card doesnt spring out, its confirmed stuck n u need samsung folks to remove it for u. They need to open up the tab.
dessq123
Adapter with a sticker, is asking for trouble. Get those without sticker, that has grooves for you to place the u-sim properly.
DellSuperman
That probably won't be a good idea as well. My adaptor (with groove for micro-sim) nearly got stuck cause the micro-sim slipped out of the groove when I was removing it. Luckily for me, nothing was damaged & I managed to remove the sim card.
bottom line, try not to use micro-sim adaptor if possible...
yangbeng
anyone syncing the hotmail account using the tablet? it seems tat the tablet is having issues of not being able to retrieve the emails from the hotmail server when i set the retrieve mode to 'manual' instead of 'push'.
any advise anyone?
daniel_83
any advise anyone?
what issue?
Cannot connect to server?
nlst74
hey guys, do you turn off the device completely at night?? I press 1 time and the screen goes off, thought considered off liao but in the morning, bat is FLAT!! very diff from ipad which 1 touch is totally sleep and batt seems ok the next day...:s11:
dessq123
Are you downloading stuff from the internet? If not, its a batt failure, get it fix.
dessq123
+1. Tabs don't like apples.
yongck7
For Andriod, the night never sleep.... this is something we all have to bear with it. I remenber there is 2G/3G toggle app in the market, not sure this help to prolong battery life. Hope someone can develop a program to auto turn off 3G and set to airplane mode at predefine timing...
daniel_83
must be something running in background
email? facebook? etc
i can achieve only 1% drop overnight if i off my wifi and data
WestGuy
New firmware KH5 now available
DellSuperman
Juice defender has this feature.. search for it in the market place.
DellSuperman
Try stopping all background programs and freeing up the RAM before turning off the device. Or do a restart for the device before sleeping.
Probably there is some program running or downloading something at the background, that's why its draining so quickly.
If its still draining so quickly, its most likely a battery fault then.
*pardon my post spam cuz I'm using my phone to reply so its quite a pain in the arse to use the multiquote function*
Tuakong
Intend to bring my tab overseas but hotel only has free hi-speed Internet connection via lan cable.
Anyway to have the tab access the internet via an intermediary device?
