chuppychup
- Aug 13, 2004
btw i read from previous post that in ICS it is possible to show the battery level in % ? how to go about activating this ? cant seem to find the option
sigh....thanks for confirming....guess i will live with the batt drain for now
I am a nut on rooting but wish to do the root for my samsung note. any expert can lead me.
also what is vol-/home/power combo
and select factory reset.
How to perform it !
Please help!![]()
after update from starhub. ..the google play got problem..cant update apps
anybody got this problem?
hi everyone.. currently i'm on ics le.. but y i cant download the flash player leh? can anyone help? thanks a million..
so... in conclusion....
we MUST do a factory reset BEFORE update to ICS?? is it?? (in order to avoid or prevent any issues)
paiseh ah... noob in android...![]()
Boss, you missed the warning on the first page lor.
If you read... cannot use CWM recovery to wipe...
hmm.. i didn't wipe before updating..is wiping after updating alone ok? since i cant downgrade...no root.In simple term yesh, due to the fact, it is a complete different OS.
oh... bro, sorry.. how to do a full wipe? what should i look out for (for example... what data should i save/backup?) using what to backup? kies (pc) can?In simple term yesh, due to the fact, it is a complete different OS.
sorry... new android user... less than 3 mths nia...![]()
I just realise something after I've upgraded to ICS.
When you go to Settings and Applications, ALL the apps are apparently 'active', meaning the 'Force stop' button is highlighted for all of them! Previously before the upgrade, I had some apps that were running in the background and consuming battery quickly. Force stopping them stopped this. I wondered if this is one of the cause for the high battery drain. I'm currently going through every apps to force stop, since this is abnormal unless you opened the apps before.
Go to Settings > Display > tick on Display battery percentage.
