Just Me
- Jan 1, 2000
Where's A concept and the damage for this SP?
The S3 screen cannot be protected/covered 100% cos the edges are all convex & not flat. Screen protector has to be smaller or else the edges will peel off.
Not out yet right? I mean in shops..Try SPIGEN SGP screen protector... Full coverage...
? seriously
Where can i buy good privacy sp?
Sounds like a Sony Xperia S with dataflex high res SP.![]()
i bought the below sp from the web link
Protectionfilms24.com | Vikuiti? Mobile Privacy Film for Samsung Galaxy S3 I9300
Are you saying this originally costs $40 since you are selling the remaining piece for $20? In that case, I'll wait for the SGP oleophobic.. thanks..Basement of Ion. Anyway the pack comes in 2. So if you just want one, it costs $20. I just fixed it today It does not cover edge to edge. I must say the quality is very good (similar to SGP oleophobic in terms of clarity)with no rainbow effects.. tired of the ones with the rainbow effect incl dataflex.
thanks , how is it ? does it affect the screen v much ? as in make the screen v dim n not clear etc? review pls![]()
i find it ok, dun have the rainbow effect. It is slightly thick and doesnt affect the touch screen capability(which i thought will). Application is very ez
so its a good buy ? cos my previous phone Privacy SP after pasting , the screen look abit dull , other than that nothing much . so i scare this would affect the amoled screen![]()
for me is yes its a good buy![]()
ok thanks .. the quality is good right ? cos the packaging seems cheapo
i placed order liao, how long it takes to arrive for urs?
