iPhone 5 Accessories Showroom (NO SELLING)
argentinafa
Mbs epicentre got sgp bumper?
I was quite frenzy over iPhone 5 cases that I have gone to epicentre 313 Somerset, ION, Taka B2, Scotts Square, Wheelock Place and lastly MBS.
It should be selling quite fast, coz I see very limited stocks. Mostly its the white color.
PM FlushX bro if you wanna some savings.
dennisc
anyone knows where is selling the 3rd party USB power cable for iPhone 5? The original is selling at $28 (too expensive)
FlushX
no 3rd party in the market now. you'd be lucky to even get the original one at $28, that is if you can find in retail stores now :o
deep3lue
using a pouch would help
An Oakley-thin pouch might not do much help. If you use Fabrix maybe but then again sometimes it's when removing the phone from the pouch in a hurry that might cause one to accidentally let slip the phone out of your hands and pouch onto the floor.
aileen99
just to let anyone know if you want to put autozkin.
It come with front, back and 2 set of sides (but no coverage for bottom part)
i DIY myself cos the staffs say need alot of time and they say they will not be able to do a proper job.
U need soap water and hair dryer.
no instruction was in the package. even on the website hmm. thai video??
I do the installation at 8pm finish at 11.30pm ( maybe i wanted to prefect it so took longer) although say use hairdryer but i blow very long also like no use. I decided best to leave it overnight. U will need a card (not provided) to squeeze out the excess. then although still have some tiny water marks, it will disappear when dry. u can redo again if u make mistake by spraying the soapy water again.
Outcome- I try before wrapsol, bodyguardz, invisible shield, lucky labs for my apple stuffs. this is something different. its glossy feel, smooth and non sticky feeling. it not much will attract dust.
overall, not bad. give it 7/10 because never have bottom coverage. i see after 1 week whether will peel or not.
