M1 FIBRE BROADBAND DISCUSSION / NETWORKING SETUP / INFO / PROMO
starbuckss
Dear ahwise, since I guess the typical average spew for M1 fibre is around 90+ Mbps, than I am wondering why is there a need to subscribe 200Mbps plan? Can advice?
Loirev
Bandwidth in each household is shared. So if you got a number of person in the house want to use at the same time, and they are bandwidth heavy, you may need the extra bandwidth.
Eg. Dad --> Video confernce
Mum --> apple tv
Son --> Gaming
Daughter --> Skype
All are bandwidth intensive.
My two cents.
AhWise
like what bro Loirev had mention, it depends on your usage by your family members. even 2-3 person in the home but intensive usage may end up slower connection.
a rough gauge is to use your current broadband as a benchmark and see if u need a higher speed connection.
Below is how i usually advice my customer on the type of plan to take:
1) People whom subscribe to 200Mbps are those who are already on 100Mbps plan feels 100Mbps is not enough thus go for 200Mbps.
2) If u are a 10Mbps user and is already sufficient, then 100Mbps should be enough for u.
starbuckss
Dear ahwise, sorry to disturb u again.
I have made my purchase of Asus RT66U this afternoon and had my wireless set up.
But base on my result from speed test, below are the information:
Tested at 1700H LAN:
Ping:5ms
Download: 140.46Mbps
Upload:81.71Mbps
Tested at 1705H Wireless (line of sight less than 3 meters):
Ping:15ms
Download: 37.58Mbps
Upload:16.61Mbps
It seems that there isnt much diff vs my previous wireless router (Dlink DAR-655)
I have set to wpa for the Asus RT66U. Do you know what is wrong?
As many mentioned that Asus RT66U is the best, thus I made that purchase but doesnt seem effective.
Hafi
my M1 line can sustain download speed of 10.5MB/s downloading a 10Gb game via homeplugs on Steam. Took less than 10 mins, as opposed to the estimate of 2hrs on Steam... not too shabby.
add: my mum is streaming show via PPTV at the same time and no lag was seen.
finalforce
Ping:5ms
Upload:81.71Mbps
Ping:15ms
Download: 37.58Mbps
Upload:16.61Mbps
I think yours is 2.4GHz band wireless. That one is quite weak because of interference from other routers. You should get a 5GHz adapter. It works like magic because almost nobody uses that band. For me there's only one 5GHz network around me - mine.
starbuckss
Hi finalforce, my router is asus rt66u, dual band with 2.4 and 5 GHz. R u referring to setting the 5GHz ? I have done so with 2 diff ID. But can't detect 5GHz from my iPhone and laptop.
Lucas28
hey guys..noob question...signed a m1 100Mbps fiber line..was planning to buy esr9850 today...but end up bought TP-link WR1043ND..anyone has experience with this model?
AE2012
I'm upgrading to the M1 fibre broadband (100 mbps) + home fixed voice service this Thursday.
1. I'll be using homeplugs. Since my fibre broadband is only 100 mbps, can I get the 200 mpbs homeplugs instead of the 500 mpbs homeplug? It shouldn't affect the speed of the connection right?
2. The connection will be Fibre Broadband connection point --> modem --> router --> homeplug, right?
3. Where should I connect the cordless phone, is it to the modem or to the router?
4. What router should I get for this arrangement or there is no need for me to get a router at all?
5. Usually what will be the speed that I will get in this arrangement? 50 mpbs from the homeplugs?
Sorry for the noob questions. Thank you in advance.
AE2012
Hafi
AE2012
1) buy the 500mbps model safer, as with any other electrical products, there is a factor of inefficiency so a 200mbps plug will not reach the full rated speed or worse can't utilize the subscribed bandwidth 100%. The 500mbps plugs have been known to be stable & works well for most of the people but your home electrical system also play a part in the network performance, if it sucks... a 1gbps plug also doesn't help much.
2) if you have all your PC/laptop systems running behind the homeplugs (inside room), you may position your router after the homeplugs. Fibre Broadband connection point --> modem ONT --> homeplugA --> homeplugB --> router
3) phone is on the jack behind the ONT modem provided by M1, your router has nothing to do with your phone.
4) if you are using only one comp and does not need wireless access, router is not required but if there is any other peripherals that need network access, you need a router.
5) again, this will be determined by your home electrical wiring condition. If it is good, you will have no prob attaining 100% subscribed speed like mine but if it sucks then worse case you can below avg performance.
hwmook
Ping:5ms
Upload:81.71Mbps
Ping:15ms
Download: 37.58Mbps
Upload:16.61Mbps
Its the damn laptop wireless chip that is the bottleneck. You buy any router also won't change that fact. You need to use a dual band wireless adapter so that you will not be bottlenecked by the wireless chip in your laptop.
*adiBOY
Anyone knows if current subscribers can still buy the RT-N66U at a discounted price?
starbuckss
Ic. I think so too. And iPhone 4S can't support 5ghz also. Hai sian
starbuckss
Anyone interested in my D-Link DIR-655 Xtreme N Gigabit Router pls let me know. PM me the offer price. Thanks
martin
I have also subscribed to M1 100mbps plan, and unsure which modem to get.
I am not sure whether I need a dual band router or just a single band will do. I will mostly be just using an iPad, sometimes I may also have a PC on as well via wired connection. Worst case scenario, I may also have a notebook connected via wireless but this rarely happens. I don't game, maybe video viewing, yes but mostly just normal surfing.
Any specific suggestion for a router for my needs? I try not to spend more than necessary.
Lucas28
yeah..also...what is the difference between router with and without "The Next Generation Broadband Network (NGBN) Ready"??
AhWise
nowadays laptop tend to be dualband compatible. if foresee yourself getting a new laptop or devices, might as well go for a dualband router. save yourself from upgrading again in future.
AhWise
Ping:5ms
Upload:81.71Mbps
Ping:15ms
Download: 37.58Mbps
Upload:16.61Mbps
the default setup by Asus rt66u i think its set to AES + TKIP.
I set it to AES only though. you may wanna try that?
