[Maylyn's Review] ASUS RT-AC66U Dark Knight Rises
eyz
Hi guys,
I just got this router. and am wondering whether it is easy to setup.
i using a starhub d-link as the modem and bridged with a singtel pace as a wireless router.
i intend to use this rt-ac66u to replace the singtel pace for the moment. no intention to go direct ont, as i will be shifting to my own place soon.
thanks.
eyz
geez, after I setup everything, I thought I'll give the firmware and update.
But after the update was complete, my PC is unable to detect any wired connection from my router.
What should I do now?
:s11::s11:
cyberet
:s11::s11:
try doing a hard reset?
salivaman
i got a free rt-n56u. can i use it to extend my wireless range while using the rt-ac66u at the same time?
eyz
sheesh, i can't put my router to recovery mode.
I need to power up the router, together by holding onto the reset button for 10 - 15 secs, right?
Can get it to recovery. The firmware restoration program can't seem to find the router as well. My router should be connected to my PC via RJ45 cable, not USB right?
eyz
ok, finally got it to work again by doing the 30/30/30 reset method.
XiaoZen
my new AC66U bought on sat is still having problem after 3 nights. version 270.
Problem: Wifi is strong. but connection to internet intermittent. user having problem login to wifi especially through mobile. Laptop seems alright. like some of the user, it's good every night after i tweak the setting, then in the morning problem arise again. funny.
last night tweaking
2.4 Ghz Frequency
Wireless Mode: N Only
b/g Protection: Disabled
Channel bandwidth: 40 Mhz
Control Channel: Auto
Professional page suggested by RMerlin
Enhanced interference management: Disabled
5 Ghz Frequency
Channel bandwidth: 20/40/80 Mhz
ASUS RT-AC66U Wireless Router - Wireless Networking
http://www.dslreports.com/forum/r27645647-ASUS-RT-AC66U-Wireless-Router
current setup
white ONT-> WAN port - RG (Huawei M1) -> Lan port - AC66U
AC66U mode set as AP. (192.168.1.2) DHCP off. 2.4ghz and 5ghz SSID same.
RG (Huawei M1) DHCP on. set starting from 192.168.1.3
what else did i miss?
I need to RG for digital phone...
phayze
Got disable RG wifi?
last night tweaking
2.4 Ghz Frequency
5 Ghz Frequency
ASUS RT-AC66U Wireless Router - Wireless Networking | DSLReports Forums
current setup
XiaoZen
last night tweaking
2.4 Ghz Frequency
5 Ghz Frequency
current setup
up for advice... :(
XiaoZen
Enhanced interference management:Yes < only for SG who stay in HDB
ok.. will try..
ytd, i can access AC66U UI with IP 192.168.1.2. today i cant.. funny.
hiaz..at least now got pretty stable internet connection.. wait 2 weeks after my black ONT (no need RG) is installed then try again...
HuatKway
Btw can i check if the utility driver for PCE66 necessary to get full AC speed? I have to uninstall from my windows 8.. it was the culprit causing unknown crash and reboots in my system after installing.
