-=OFFICIAL=- EDMW PHOTOGRAPHY CLUB - - - Part 13
noobzpro
Thanks guys for your recommendations. Yes thats what i thought soo too... Buying a lens which i will probably use very rarely in sg....
MarkersNg
If you don't think you'll use it ever again, can consider renting one
Mach3.2
moi in the past always successfully use this method de..
which is..
power off fone
vol down + power button
reboot into recovery mode
*android lying down*
go to moi fastboot folder on my laptop
open commandprompt there
type in customrecovery XXXX (cant rmb now)
den the fone will auto reboot into the recovery menu..
now dunno after last SlimBean update cnanot le :(
Fastboot flash recovery XXX.img
tecnica
Kns this ah kiat nv install cwm, how to boot into recovery when it doesn't even exist in the phone?
tecnica
He boot from those one-off recovery la, not permanent one. Once you done and clear cache, the recovery is gone.
MarkersNg
moi remember indi-god say ThinkTank Retrospective bags will turn soft after a while
ThinkTank Streetwalker bags will or not ah?
indigo22
Just flash the recovery and be done with it, seriously...
Fastboot flash recovery xxx.img
as mentioned, i have tried this method but it didnt work...
cant imagine why i would ask for help if it worked anyways..
indigo22
moi remember indigo22 say ThinkTank Retrospective bags will turn soft after a while
u mistyped my nick,editted for u
streetwalker pro will not turn saggy :D fret not..
MarkersNg
I think I'll just get a camera insert and dump it into my good old Crumpler :s13:
Vanguard Uprise 48 or Streetwalker Pro for the "more stuff" days...
