iPad mini retina cases covers and accessories
Hitokirii
Is the original apple smart case good?
Ipad3 is using eggshell and Smart Cover for 18 months. Egg shell edges all cui already. Nv drop before
Epish`
bought $12 clear protector at adix.
Good and cheap.
premium apple reseller stuffs are overpriced.
porcu
Where to hoot this?
Bought this at Vigo city during launch day..forgot the name of shop but next to Asus store,
Already changed to Clasy glass protector which I have got from Adix today. So far so good.
Got the tempered glass installed on my mini R, Air and old ipad3 today. :D
After that I bought the sliver button from SLS and pasted it there. Sleek...:)
shadez9
Can share how much is the glass protector?
familyguy
saw this ipad mini skin cover known as slip stopper
made of gel resin skin
provide grip for user
also available in white
lucretius
Hi, woah .. where u got from and the price? definitely a wow factor.
p.s : can fit smart cover after using this glossy back case?
familyguy
absolutely able fit the smart cover with the slipstopper back
got it from a friend who is a distributor in sg for $29
fuzzybear
How Smart Cover works ah
It just a magnet to secure the flip behind ?
Wint it come loose ?
punker
Saw the slipstopper video on YouTube, does it really stick itself on glass panel? Lol. This is nice n sleek though. Does it cover the corners?
aquaing
Just ordered a piece of this and ship via vpost looks awesome no bulk!
What does you guys think?
ralliart12
Some accessories from Benks
Finally got around to applying the screen protectors from Benks. For the front, I'm using the Magic AKR glass protector:
Comes in a fairly good-looking packaging with tons of application accessories inside.
It is slightly thicker (0.3mm) than the SGP GLAS.tR NANO SLIM for the iPhone 5 (0.23mm). I suppose it's possibly because Benks is not as experienced as SGP when it comes to glass protectors, or maybe Benks have to make the glass thicker to be sturdier because it is after all, a larger piece of glass. Nonetheless, similar to the SGP, this model is supposed to have a hardness rating of 9H.
What it looks like after application.
For the rear, I'm using the Magic CR film protector:
(also bought a cheapo & poor-quality smart cover)
The Magic CR film protector doesn't have a hole for the rear mic, so I have to punch 1 myself. Nonetheless, I was taken aback when my application resulted in a lot of bubbles. It turns out that this model is literally a "floppy soft" film & not the usual slightly-stiff screen protector one may encounter. Hence, when I apply it as per normal, I encountered a lot a lot a lot of trapped bubbles. In the end, I have to lift up the film one half at a time, pull it taut, & use the provided squeegee to slowly edge the film onto the back of my iPad so that the adhesion is even & uniform. Repeat the same for the other half when the first half is properly "ironed out". Not the nicest screen protector overall, but it does make the rear surface quite grippy.
