ah_cheng1882
- Nov 25, 2006
I wrote to them again just now, saying it's silly to require each and every household to have an external antenna.
Here's the reply from their Manager a few months back. Will relate the latest reply when available
"Dear Sir
Thank you for your feedback.
With regards to your query on enabling the MATV for reception of digital terrestrial signal, the existing HDB’s rooftop master antennae (MATV) system was designed to receive analogue TV signals and will not be able to receive digital FTA TV signals.
On your concern on the reception quality for low-rise households, MediaCorp has tested the DVB-T2 standard and the results show that the reception and coverage is more robust and comprehensive. Moving forward, MediaCorp will also be enhancing their digital TV broadcasting infrastructure to enable adequate coverage even for low-lying areas.
Please do not hesitate to contact me on or email me at Zoey_MOH@mda.gov.sg should you require further assistance.
Thank you.
Yours sincerely;
Zoey Moh
Manager (Planning)
Digital Broadcasting Deployment Office Division"
"Dear Sir
Thank you.
Yours sincerely;
Zoey Moh
Manager (Planning)
If they implement it right (which they usually not). A small indoor antenna will work without trouble.
