crow_nest
- Jun 5, 2004
How long is Jimmy's magnetic cable? Asking those who bought
About the same length as the USB data/charging cable that came with the phone.
Has anyone realise that the sound for whatsapp is kinda soft even though i max the volume
I bought a Strontium 32GB UHS-1 as well. I dont think Sony is that bad either. Just dont buy sandisk. My dad had two 32GBs that died on him, and I had two 16GBs that became sot after a while.
i bought sandisk ultra, so far so good le
no doubt Strontium microSD is good, but its write speed is not that good le especially for ppl who wanna take HD photo/video
Strontium Nitro 64GB microSDXC Memory Card Review
Nobody else having this problem of whatsapp notification being soft?
does factory reset wipe telco installed junks? or only hard reset will wipe it?
10-15mins? indoor. was only testing..how long u use the camera? So far haven't encounter temp too high
mine nv overheat yet, but i was just viewing thru the setting and my phone temp report 33 34 degree liaoJust curious but what applications or stuff were you guys doing on the phone to cause it to overheat?
hmm thanx for the warningYes, at least it does for Singtel. Be sure to update your firmware first, then wipe the phone. Cos the firmware will re-add the bloats.
Any of you here missing the Sony Notes small app that used to come with Z1? I realised I'm not just missing the Notes small app, even the regular app is missing too!
