andr3wyong
- Mar 5, 2012
Nope - not on Ayer Rajah exchange ^^|
Also seems like purple having network outage now o.0 so far looks like the maintenance for VQ is indeed restricted only to Ayer Rajah as originally planned.
*touch wood*
Can go around the entire area looking for the OpenNet folks... haha!Ayer rajah exchange special
live at holland drive so i must be quite near the exchange lol
I would suggest avoiding any critical work (like gaming) till 6am haha!
Wow
Though, if you consider the cost of a 4G connection, why not just do dual fiber WAN, and get a low-end M1 connection as backup?
Edit: Or cable/DSL if you can get the cheap old plans somehow.
If I see someone playing D3 along the roadside I will say hi -.-Why not have all three?!
Dual WAN at home for backup, and 4G for outdoors.
A story I hear quite often is that the new HDBs have soundproofing in the walls that heavily reduces Wi-Fi range - not sure if there's any truth to that, but at least 2 subscribers in Sengkang have told me that.Have this odd problem in my new flat. In my previous flat the zhone was hidden inside the utility closet & was quite far from my bedroom. However my phone was able to detect the wifi signal most of the time & my note 3 had decent speeds as far as wifi standards go.
My new flat is smaller & the zhone is exposed not hidden. So by right my phone should be able to detect the wifi signals better. Not the case. At times my note 3 even tells me my network connection is unstable. Even when it is connected, the speed is a lot slower than in my previous flat. I even tried sitting on my sofa which is like 1m away from the zhone. The note 3 shows the signal as strong though, 4 out of 4 "rings".
Anyone know why? Its the same note 3, the same zhone & the same internet connection (500 mbps).
Maybe the walls did indeed get thicker? :/
Does the issue persist across all channels?
Mine is old flat in Bishan. I only use wifi for my mobile phone. Otherwise im on cat 6 structured cablingA story I hear quite often is that the new HDBs have soundproofing in the walls that heavily reduces Wi-Fi range - not sure if there's any truth to that, but at least 2 subscribers in Sengkang have told me that.
does this have something to do with the plug in/plug out of the lan cable on the other ports?Sounds like interference; changing channels did not help?Mine is old flat in Bishan. I only use wifi for my mobile phone. Otherwise im on cat 6 structured cabling
Anyway i tried sitting on my sofa which is 1 metre away from the zhone. No obstruction. Same thing. Either very slow or no access.
Not yet announcedIs the promo for fair show out?
