LG G3
kennyg1969
i bought my quick circle case and the battery + charger from this seller..all authentic :D
So did i but unfortunately, i wanted the gold quick circle and it has not been shipped since 30th Jun as seller claimed LG Korea has not delivered this colour although he did tell me other colours was available for immediate shipment.
When i ordered this on 28th Jun, i was praying it will fit into my G3 since the cover is designed for the Korean set
doki81
i ordered the gun metal for my gold g3...so i got it quite fast. saturday order..got it on tuesday.
the fit is good just that the top right of the case has a cut out for antenna which international g3 doesnt have the antenna...
Computeron
LG G3 Water Resistance test
2hrs in water!!! satki...
anyway, now to approve water resis and dust proof cert cost money..
so some devices now is secretly water proof... Oneplus One is one of them.
BERSERK1980
Yeah feels good to know the g3 can take a water beating.
Uncle_Sams
Hi guys I'm thinking of getting of the G3. Just 2 questions.
1) The version sold in Singapore is unlocked right? I do travel quite a bit so this is important to me.
2) I've read that the G3 do have "over-heating" issues. Is this a real problem or just the "phone will get warm playing games or watching a movie" kinda thing which is normal for all smart phones?
Apologies if the above questions are considered dumb by some...
BERSERK1980
No your questions are valid. All local sets are of course unlocked. The only time when my set got hot was when i was charging it and under the pillow.
Computeron
mmm.. i feel my heat is normal.... the only device with its heat shocked me is SONY xperia Z
samson1
I think the heat 'issues' only arises if you are on 100% brightness all the time. But general typical usage is the same I feel.
kennyg1969
he did gave me an option to change to other colours but then i am a sucker for the gold since my G3 is gold
Uncle_Sams
Thought I should ask in case it was otherwise... I would get the "you mean you didn't know" comments from my friends...
Was considering the M8 and the Z2 but the G3 caught my eye... If the battery life was better I would say it's a perfect phone...
