The Samsung MicroSDHC is being put to the test! How much torture can it withstand?
singmob
Wah you guys like to chiong 128gb at one shot.
Me prefer to use multiple smaller capacity cards (min 32gb denominations).
Got a feeling that the 128gb microSDXC users are hardcore music listeners.
They might be fisherman too.
There is a limit of points a day for the this Samsung Evo campaign right?
Yup. It is stated but how much?
Has anyone redeemed the 20% discounts from the Samsung Rewards Program?
20% Doesn't seem worth it, 40% should be good but have to know the price at Rewardslink first.
It might be cheaper to buy from amazon or reliable Sim Lim shops without any discount. You never know... :s22:
xtramadness
No leh.. I take on photo 6-10mb... very fast my 32GB filled up... But yea.. I use FLAC and ALAC...
xtramadness
It should be working already.
Each voucher is valid for one collection or redemption, and subject to availability.
Vouchers should be redeemed personally between 11 July - 23 August 2014 at Rewardslink Redemption Centre: Sim Lim Square, 1 Rochor Canal Rd, #05-03, Singapore 188504.
Unclaimed rewards after the validity period will be forfeited.
Means should be RRP liao lor!
MoneyFace =p
Standard, a Class 6 card, is the most consumer-level card Samsung is offering and is denoted by a light blue color. It is available in 4 GB, 8 GB, 16 GB and 32 GB with a data transfer rate of up to 24 MB/s.
EVO is the next level and is in a bright orange color. It's kind of a mid-level card for those looking for a bit more performance, but not really aimed at any type of professional. The EVO cards are UHS-I Grade 1, Class 10 and are available in 8 GB, 16 GB, 32 GB and 64 GB with a data transfer rate of up to 48 MB/s.
xtramadness
Sian.. Nokia 930 dont support microsd... iPhone also :(
Else get a Samsung memory card put in expand the memory also fun
xtramadness
<-- MoneyFace =p;87264824
EVO is the next level and is in a bright orange color. It's kind of a mid-level card for those looking for a bit more performance, but not really aimed at any type of professional. The EVO cards are UHS-I Grade 1, Class 10 and are available in 8 GB, 16 GB, 32 GB and 64 GB with a data transfer rate of up to 48 MB/s. -->
Show the old ones also.... :s12::s12::s12:
xtramadness
Bro can explain wjats MLC TLC and SLC ???
Moi only know tlc in army terms is call tender loving care provided by those nicd enchik
Yes boss!
SLC (Single Layer Cell) is the highest performance BUT at a very high cost. Consider it to be enterprise grade flash chip.
Has ~ 90-100,000 program/erase cycles per cell (highest endurance)
- lowest density (1 bit per cell, lower is better for endurance)
- lowest power consumption
- faster write speeds
- much higher cost (3 times higher than MLC)
MLC (Multi Layer Cell) is the average performance, consumer grade ship
Only has ~ 10,000 program/erase cycles per cell
- higher density than SLC (2 bits per cell)
- lower endurance limit than SLC
- lower cost (3 times lower than SLC)
- good fit for consumer products. Not suggested for critical applications which require frequent updates of data
TLC (Three Layer Cell) is the lower performance and lowest cost of the lot
Usually ~ 3-5,000 program/erase cycles per cell (samsung made this even higher with EVO on their SSD, so i believe that tech is ported over now)
- highest density (3 bits per cell)
- lower endurance limit than MLC and SLC
- best price point (~30% lower than MLC)
- somewhat slower read and write speed than MLC
- good fit for lower-end consumer products. Not recommended for critical applications which require frequent updating of data
Generally, SLC drives are the fastest, most relieble and most expensive drives available, usually used in the enterprise because of their considerably higher cost. However, both MLC and TLC are widely used consumer grade memory, with MLC being better in terms of endurance.
Why the difference?
SLC Flash has only two states: erased (empty) or programmed (full).
MLC Flash has four states: erased (empty), 1/3, 2/3, and programmed (full).
TLC Flash has eight states: erased (empty), 1/7, 2/7, 3/7, 4/7, 5/7, 6/7 and programmed (full).
It’s easier to read the correct fill status when it is either empty or full, as in SLC NAND Flash. When the cell is partially full, as in MLC NAND Flash, the fill status is more difficult to read, taking more time and energy.
Like if this helps? :D
dexmus
hi friend :s13:
its true, quite a few friends encountered the same problem...so now those who use samsung devices tend to buy samsung evo or plus cards...very crafty of samsung :s13:
i have been using sandisk microsd for 2 yrs+ on samsung device so far no problem. *cont to pray hard*
how to enable the device to use 128gb microsdhc card~? :s11:
I thought max only 32gb~? :s11:
it depends on the device that u r using, whether it support up to 128gb or not.
if Samsung do come out with 128GB.. indeed ish a leap forward liao.. imagine entire SSD data in one tiny card.. :s22::s22:
but it wont be as lasting as ssd. since there is a certain lifespan for as microsd cards in terms of write and rewrite if i am not wrong.
