hi gs,
need your advice.
i had just did a reset my Fujistu L1010 laptop to factory default and installed couple of programs.
i would like to do a backup before i start to use. hopefully, it will help when i need to reset again in the future.
Can you advise on how i can do a full backup to external drive?
anyone can advise?
Hi all,
My PC is on Win 7 Home Premium and recently it gets stuck at the Starting Windows screen, just before it goes to desktop. I have tried Startup Repair as well as System Restore but to no avail. I am able to access through Safe Mode though. I have even tried formatting but the problem just came back after a few days. Any ideas?
Bro gs, I have a Samsung notebook when power on but nothing appear just the power button led light up and fans running. Any idea what's wrong?
2nd problem, my pc screen freeze and went black. After restart heard 1 long and 3 short beep sound and a red led at motherboard light up. Is that graphics card going to up lorry? Thanks
hi all, anyone can give a helping hand?
Hi Nigel, is your shop open today?
yes.....it is open
Just wanna thank Nigel for the quick assembly of my ssd. Fast and efficient service.
Anyway Nigel, would like to ask - after installing my Samsung SSD as the main drive, there's occasional blue screen which occurred previously when I was using my Corsair SSD as the main drive. Blue screen error mentions about Physical Memory Dump. Could it be my Corsair SSD that's faulty which is causing my Samsung to have the blue screen as well?
u can bring down for a fast check if u want..most likely is a mainboard/ram problem
