Full reset after upgrade
Hello All, i just updated to MERLIN 376.44 and did the hard reset, but got an issue, not sure if this is a bug or my mistake?
I use below setting for 5GHz wireless
--> Wireless mode: "N+AC" ,
--> Channel Bandwidth: 80MHz
--> Control Channel: 153
After clicked "Apply" and cross checked with PCE utility, the connection always stay @ 5GHz 20MHz, and the channel remained at 36 instead of 153 in setting, is there anyone encountered this? Any suggestion?
Thanks in advance.
There are other people reporting similar problem with 376.44 at SNB:Hello All, i just updated to MERLIN 376.44 and did the hard reset, but got an issue, not sure if this is a bug or my mistake?
Thanks in advance.
Howdy folks,
Initially I wanted to wait for newer Asus source code before pushing out a new release, however in light of the recent OpenSSL security fixes I decided to publish a 376.45 release with the current Github content for all supported models.
This is essentially a security + bugfix release with little frills, so I'll just dump the changelog here:
376.45 (17-Aug-2014)
- NEW: Compiled vsftpd with SSL support (must be manually configured if you intend to use it)
- NEW: Report FA state (Level 2 CTF) on Sysinfo page.
- CHANGED: Updated dropbear to 2014.65.
- CHANGED: Updated openssl to 1.0.0n (numerous security fixes)
- CHANGED: Updated lzo to 2.08
- CHANGED: Reworked VPN Server pages to be more intuitive
- FIXED: Garbled client dropdown selector on DNSFilter page
- FIXED: The Comcast neighbour solicitation block wasn't enabled anymore (regression in 376.44) (Patch by Sinshiva)
- FIXED: 5 GHz N+AC mode was incorrectly setting router to N-only mode (Asus bug, fix backported from 2381, additional fix by me for AC66)
- FIXED: PControl page failing to display on French and Italian locales (Asus bug)
- FIXED: IPv6 can occasionally fail to work properly when using a PPPoE WAN interface (patch by pinwing)
Downloads are here.
.44 has many new features and is quite stable. I have also rolled back to .43 because .44 reduces my wifi range significantly
See this link for the two documents that relate to this. The second document shows the type of things the FCC asks out of manufacturers now before granting certification.
https://apps.fcc.gov/oetcf/kdb/forms/FTSSearchResultPage.cfm?id=39498&switch=P
One interesting bit there that relates to the use of channel 12 and 13, as an example:
So giving end user manual control of it is definitely out of the question for future products. No idea how strict they are about existing, already certified products, but in any case get used to not being able anymore to control this, as it will be the norm from now on.
Any reason why you are looking for such an old version?Hi, may I know where can I download ac66u firmware 3.0.0.4.270? Thanks
After upgrading to the lastest firmware, found out at channel 12 & 13 missing and also the tx power adjustment no longer in mW only in %. So thinking revert back to the firmware I knowAny reason why you are looking for such an old version?
RMerlin's 270.26b is still available for download.
You don't have to go so far back (those old f/w might have some security issues).After upgrading to the lastest firmware, found out at channel 12 & 13 missing and also the tx power adjustment no longer in mW only in %. So thinking revert back to the firmware I know
Just have to roll back to 374.x like 374.5517 (stock Asus) or 374.43 (RMerlin) and you should get back the mW setting.
Do a factory reset after flashing.
Your ccode values are probably set to US (no chans 12 & 13).Hi Ah-Pin-Kor, thanks you for the help, got back the mW setting ability. But still missing channel 12&13. For what I know ac68u got channel 12&13.
