shidenx
- Apr 17, 2001
can show picture of the stain?
quite surprised to hear that the black leather can get stained, was thinking of buying the dark blue one cos it's dark and less prone to stains
real leather is an absorbent material so it is not surprising at all nor isit immune to stains even if dyed dark.
It naturally absorbs oil and moisture from the surroundings while it ages; smudging the dye ,aging or staining it. Enough to cause discoloration or uneven color distribution after some time and some people like this some prefer their perfect dyed look.
Apple did have this disclaimer on the store for the case.
*This case is made from natural aniline leather. Its appearance will change as you use it.
Only the back is bling bling. And you're assuming I'm a guy?
