31.50 after 10percent.
Not sure why everyone is getting the $35 Tunewear EGGshell. EGGshell doesn't have the speaker funnel and is more expensive.
I bought the Tunewear SOFTshell, comes with the speaker funnel design. RRP is $25.90, if you have Challenger membership will have 10% discount.
Here's how it looks like:
Xtremeguard for iPhone 6 arrived!
Seems like the front protector covers entire screen.
Waa... u pay for express delivery, izzit? When did u order? Mine was shipped on Sept 20. I'm still waiting long, long time for mine to arrive.
clear type tends to be slippery.
Will suggest get those matte frame type & depends on brands.
Agree with garychengjw. You can consider the Tunewear softshell. I'm using that as a temp case, and it feels 'grippy'.
does it add bulk? thinking buying this![]()
looks good..
i went to a few challengers on Saturday.. but they do not have any iphone 6+ cases..
will keep a lookout for the tunewear case..
looks good..
thanks
RRP 25.90?? which challenger u went to? Mine was 35 bucks
Erm i got the softshell and i paid 35 from Funan Challenger. Which Challenger did u went to?imo nope. Thickness is 1.4mm. You can take a look here.
On the contrary, Vivo challenger has more iphone 6+ covers than iphone 6. They have tunewear for the 6+.
Differences:
SOFTshell ($25.90)
1.4mm thick
Case covers entire phone, c/w dust covers for the charging/audio slots as well.
Has a sound funnel design to amplify sound output towards user.
EGGshell ($35)
0.8mm thick
Case DOES NOT cover entire phone (top and bottom not covered, no dust cover)
No sound funnel design.
So depends on which kind of protection you want.
The below will save SPG neo hybrid button defect.
Cheers. Is perfect now. No need to manually DIY
Differences:
SOFTshell ($25.90)
1.4mm thick
EGGshell ($35)
0.8mm thick
