Sian ><
Dunno what to pamper myself this year end.
Should i get a dual gtx970 with water blocks and let go my dual 290 cheap cheap
OR
Should i get a new water blocks for my r9 290s
OR
Should i let go my monitor and get a bigger monitor
OR
Should i let go my AVR and get a new AVR.
Confused.
I don't know, is it a good idea to have a 30+ inch 1440p monitor so close up in your face?
Also, since the GTX 970 is only a bit faster than the R9 290, don't think there will be a great improvement going from R9 290 to GTX 970 even if you win the GPU silicon lottery.
Since you are saying that your rig is generating some serious heat into your room when gaming, why not just buy some large and powerful fans to help improve air circulation in your room and blow out the hot air faster?
Also, just how much spare change do you have? First, a 4K TV and now a rig upgrade.
