HeeroYuy84
- Apr 22, 2002
**** device.. slightly over a year and not working liao.. reset and console in cannot login, cannot access the management page to go in also
You might be able to get an RMA if you contact Ubiquiti support directly with the date code and mention that the USB drive failed.Made to last a year perhaps
Worth a try. The USB flash was especially crappy in the first few batches.really? even after warranty period of 1 year?
Yeah that would work too!Faster to buy a Sandisk Cruzer Fit than to RMA right? The original flash drive is so crappy that even after formatting I couldn't get any OS to read it.
Hi,
I am looking to buy this router. I currently have cable internet 100Mbps/2.4Mbps
I am currently using a cisco cable modem which is bridged to a Netgear WNDR3700V2.
I also have a Cisco Meraki Wireless Access Point and a Netgear GS108 8 port gigabit switch.
I know this device only have a limited amount of ports. Will plugging in my 8 Port netgear switch into eth 1 on the ERL decrease performance in anyway?
Thanks,
K.
can i make one to one clone. in case my usb die in the future also. kiasu![]()
Yes for a home setup.
I like to play around with IT equipment![]()
