what is self healing technology?
this answers your query
the lg g flex heals when there are scratches
The LG Flex 2 gives an ergonomic hold on the phone whicb sits comfortably on on's palm. With its 5.5" 1080p screen, 2GB ram, 16gb rom, nothing can stop in its way.
one full day of normal use without recharging.how long the battery can last?
what's the battery life on this device?
and the micro SD storage up to 2TB? what the![]()
post #2
- the flex2 runs on Android Lollipop 5.01 with a Qualcomm snapdragon 810 processor.
the 810 does heat up upon usage but the heat is still bearable.
- did i mention that there is a curved tempered glass screen protector for this phone?and i thought curved screen protectors was not possible. but then, the phone already comes with gorrila glass with a special in-house treatment that makes it 20% stronger.
- a feature not loudly advertised is the self healing back cover from the original flex. it does heal the minor scratches but please do not take a penknife to scratch it.
- flex 2 comes with 403ppi on a 5.5 inch 1080p screen. imho, its a great improvement.
- the 23-degree arc makes answering the phone in a noisy environment easier cos the speakers and mic are in the proper place.
- when rested on a table, the curvature + back speakers bounce the music off the surface, making it sound louder. no worries about the speakers being too soft or missed calls.
- Q apps. there are a few useful Q apps from LG thats quite good for everyday use. Smart Notice shows u the notification cards on calendar events, weather information and other tasks. Dual Window allows u to run 2 apps on a split screen simultaneously. there is also GlanceView, which allow u to check the time, date and missed notification without waking up the phone. just simply swipe downwards from the top of the display at lock screen.
- the flex 2 comes with Bluetooth 4.1, NFC and two different storage options (16 and 32GB). It includes either 2 or 3GB of RAM depending on availability.
- it also comes with a 13-megapixel back camera with laser autofocus and OIS+, 8x digital zoom, panorama shooting, a gridline overlay to help compose pictures and four sizing options (ranging from 2,048x1,536- to 4,160x3,120-pixel resolution). It can record HD, full HD or ultra-HD 2160p video, as well as slow-motion at 120fps.
- the front camera is 2.1 MP and it comes with a "beauty meter" where u can soften up the selfie a bit without using additional app
- it supports local 4G LTE
- flex 2, while using the stock charger, is able to regain 50% charge in around 40 mins. pretty fast for a 3000mAh battery
- comes in red or gray. imho, just get the red.
wifey had been using the phone for more than a month. only complains about the phone getting a bit hot after prolonged usage. seems like the heat is manageable and not scorching as reported.Qualcomm MSM8994 Snapdragon 810 Quad-core 1.5 GHz Cortex-A53 & Quad-core 2 GHz Cortex-A57 battery life should be ok.
the problem for the 810 is that it is known to be a hot chip. There are rumours that Samsung skipped the Snapdragon 810 due to the heat issues.
The HTC One M9 which features the 810 is also criticised for the high temps.
The G Flex 2 seems to have better thermal management, but it does so by throttling performance.
http://www.phonearena.com/news/The-secret-of-Snapdragon-810-keeping-cool-50-shades-of-thermal-throttling-on-the-G-Flex-2_id66053
The G Flex2 supports the microSDXC standard, which allows for a capacity of up to 2TB. So by right any phone that fully supports microSDXC *should* be able to take up to 2TB.
Anyway, it's quite a redundant point for now since the largest microSDXC card is only 200GB right now![]()
post #2
No need to worry if 2TB is true. Now the max for microSD is 128GB (readily available to buy) and not really that cheap yet compare to 64GB. Wait for 256GB comes then 128GB price will drop. By then, should be more VFM. to get 128GB.
