[SIC] Hoot Club! Post Your Technology/Hardware Related Purchases NOW! - Part 3
shadow84
in here :
1) Custom Water Cool Z97 Rig > 4790K+Maximus VII Impact > 295x2 > Caselabs S3
2) Custom Water Cool X79 Rig > 4960X+Rampage IV BE > GTX Titan Triple SLI > In Win D-Frame
3) Custom Water Cool X99 Rig > 5960X+Rampage V > GTX Titan X Triple SLI > Caselabs SM8 with dual pedestals
So what would be the 4th rig specs? Xeon cpu?
lib_rian
Cos I see u keep buying alot of high end stuffs plus powerful watercooling stuffs.. wonder what u reali do with them..
Nitrile
I have this problem when i ovehaul my previous desktop too. Its something to do with the power supply i think as once i re-use my old power supply and it boot accordingly.
you are right.. found out only after i removed the cooler pump to check mobo for bent pins! now need to get some thermal paste also.. zzzzzzzzz
noidea
bought this just now. Left two on shelf at BB.Have already decided to get corsair RM650. was skeptical bout this PSU and many have sworn on it. Even reviewers. so ... I bite the bullet and give it a go.
Previous PSU was Seasonic M2II 650W modular. No idea why it gives loud sound out of sudden ... :s22: even while surfing the net. hope I bought the right choice ... :s13:
twlee88
haha.. so found out the root problem already?
totally understand your feeling. hate the thermal paste part the most. used 3 for my previous overhauling.
but...once u see its all works...u'll get that super satisfaction feeling :s12:.
Nitrile
haha, now got another problem.. cannot fit SLI in my case unless i remove drive cage :s13:
Gattberserk
My work PC hoot
Missing from the pic are a Samsung Evo 850 1GB SSD, two WD Black 3TB (running RAID 1), and a set of quad channel 16GB Kingston HyperX Predator DDR4 3000
I initially bought a 512GB M.2 SATA card for the system, but discovered that the mobo only take M.2 PCI-e........ so switched to the Evo 850 SSD
Where do u get the gainward card? I never seen a gainward card locally before, especially the phantom one.
hengheng220
some humble samsung storage hoots~ As compared to the few post earlier mine is some peasant hoot hahaha
